Wondering if this low (see image from Windows 10 below) Ethernet speed is normal? The green LED on the ANAN is flickering pretty fast (using a dumb Ethernet switch). I was expecting to see much higher numbers. Protocol 2 in use.
Is this Ethernet speed "normal"?
Thetis v2.10.4.3 x64
Protocol 2 v2.2.2
Protocol 2 v2.2.2
Re: Is this Ethernet speed "normal"?
Here's my numbers, running RX1 and RX2, and taking up most of the screen on a 4K monitor. A few moments prior to grabbing the screenshot I was only running RX1 and the ethernet throughput was 50% lower, at 39 Mbps (you can see the jump in the ethernet icon):
So if you're running a single receiver in a lower screen-resolution session then I'd expect your ethernet throughput to be something lower than 39Mbps, all other things being equal.
Hey Mark!
Yes, just running RX1 so I guess the speed is "normal."
Thanks for your gracious help again yesterday!
Protocol 2 v2.2.2
Protocol 2 v2.2.2
Very welcome sir, we accomplished a lot and I always enjoy your visits.
