w9ac
Postby w9ac » Sat Sep 25, 2021 4:52 pm
ramdor wrote:fixed in 21k already, but thanks :) Will probably be released sometime this evening (uk time)
OC Control working fine now. Thanks!
DL8LAQ
Postby DL8LAQ » Sat Sep 25, 2021 5:16 pm
ramdor wrote:UPDATE 21k
add: auto agc options added to AGC/ALC setup tab. This is experimental and relies on panadapter noise floor calcs
Auto AGC is very nice, but it requires a different offset for my vhf xvtr. The noise floor on 10m is just below -120 dBm, but just below -140 dBm on VHF. Level CAL on HF, 6m and 2m is performed by use of a signal generator.
Postby ramdor » Sat Sep 25, 2021 5:18 pm
w2ner wrote:This auto AGC is very nice, would be great to have a button under the AGC gain control to enable auto AGC.
yeah, it'll need some more work for sure, it is totally experimental. I need to expose a couple of settings that change the sensitivity, attack, etc of the noise floor algorithm. Ideally, the gain slider with auto agc enabled would adjust the offset. perhaps right click the slider and the grab handle changes to a different colour to show auto agc.
I really need to start making headway on splitting RX2 from RX1 in the display engine, and rendering 2 directX surfaces. With the current list of change/updates and fixes, probably mid Oct to start working on that.
Postby ramdor » Sat Sep 25, 2021 5:22 pm
yep, eventually it will use an agc offset per band or something. Needs more work for sure, just the initial implementation.
Yes, looks like I need to subtract the transverter gain before firing it off to the AGC. The snr readings will be different on 10m and 2m as they should be, but the agc will be using 10m floor. I will sort this for next version.
w2ner
Postby w2ner » Sat Sep 25, 2021 5:25 pm
Great, thanks Richie
Postby ramdor » Sat Sep 25, 2021 5:29 pm
updated previous post Nick. I need to remove the transverter gain before firing it off to the agc. Should fix that issue.
Postby ramdor » Sat Sep 25, 2021 5:30 pm
i'll email you a link later with a change for you to test.
w2ner
Postby w2ner » Sat Sep 25, 2021 5:36 pm
ok, no email yet. w2ner at icloud dot com
Postby ramdor » Sat Sep 25, 2021 5:38 pm
w2ner wrote:ok, no email yet. w2ner at icloud dot com
takes a while to code these things ;)
Postby ramdor » Sat Sep 25, 2021 5:45 pm
sent you a PM on here
W1AEX
Postby W1AEX » Sat Sep 25, 2021 5:53 pm
Just a quick note that all the button packs at my site are updated with the new xPA button. Download whatever button pack(s) you need and unzip the contents into the Console folder of the skin(s) you wish to update. Note that none of my skin download packs are updated at this time so if you grab any of them you will need to update the buttons in them with the desired button pack.
Button packs are near the bottom of the skins download page: http://www.w1aex.com/hpsdr/hpsdr.html
Postby ramdor » Sat Sep 25, 2021 6:06 pm
Transverters
Here is a link to transverter modified version of 21k.
pre 21k2 for testing : https://bit.ly/3lRRQK4
It removes the transverter gain for the auto agc calculations.
DL8LAQ
Postby DL8LAQ » Sat Sep 25, 2021 6:21 pm
ramdor wrote:Transverters
That works perfect!
Postby ramdor » Sat Sep 25, 2021 6:26 pm
That works perfect!
great :) Thanks for the feedback. Have a good weekend. I think I am going to unplug for the duration ;)
73 Richie.
DL8LAQ
Postby DL8LAQ » Sat Sep 25, 2021 6:29 pm
Thank you! Have a nice weekend! :-)
PD3LK
Postby PD3LK » Sat Sep 25, 2021 8:18 pm
Hi Richie, thanks for version K, it runs nicely but i noticed one little thing:
switching between Collapse and Expand leaves the WF and FTT black (Power button off/on resolves this)
Very happy with Auto-AGC, works also fine with Panafall, not only with Panadapter. :P
Postby ramdor » Sun Sep 26, 2021 3:48 am
PD3LK wrote:Hi Richie, thanks for version K, it runs nicely but i noticed one little thing:
good stuff, yep. There will probably be a 21k3 later today, as couple of things need fixing (like that black display issue).
Postby ramdor » Sun Sep 26, 2021 12:02 pm
UPDATE 21k3
Sorry for the spam of updates this weekend. Improved and fixed a few things. Post #1 updated.
Also, thanks to all who maintain the buttons/packs.
Vid about some of the changes : https://youtu.be/Ci_9IRMHZNE
73 Richie.
21k3
fix: display may go black when resized
add: xPA override for OC RX pins
add: AGC/RF gain slider thumb will highlight green if auto AGC on
add: right click AGC/RF slider to toggle auto agc
add: right click on RX/TX eq buttons will show eq form
add: right click ps-a button opens linearity form
add: right click TUN opens setup + transmit tab
add: right click 2TON opens setup + test tab
add: right click xPA opens setup + pins tab
add: attack time for auto agc noise floor estimation. Defines the 'speed' at which the smoothed noise floor moves
change: xPA button will always disable on TX if [allow hot switch] if off in OC setup
change: improvement to initial noise floor state
Postby K1LSB » Sun Sep 26, 2021 1:30 pm
ramdor wrote:Sorry for the spam of updates this weekend.
Haha, look at this guy, apologizing for the nonstop updates! :P
Thank you very much for your tireless support, Rich!
Postby oe3ide » Sun Sep 26, 2021 1:31 pm
Thanks Richie, 21k3 runs perfect here :-)
Guenter dk8dx
Postby Guenter dk8dx » Sun Sep 26, 2021 2:51 pm
Hello Richie,
First of all, a big compliment and THANK YOU for your great work.
(Sorry, my english is bad, use google translation)
I have a big wish to Thetis.
When I press the TUNE button, the PTT output on the Anan should be blocked (off).
Why!?
I use Anan7000dleMK2 with ext. Amp LDmos 1K5.
I use the Tune button with 10W drive power for antenna SWR tuning.
If the external amp is ON now, 800 ... 900W power would come.
You can't tune an Ant with it and the amp would be defective.
... At the moment you always have to put the ext amp in standby mode.
All of this could be much easier and safer.
Hence the request:
Can you change the software that the PTT Outp. Pin on the Anan OFF (low) goes when the TUNE button on the console is pressed)
.... In addition, this function should be able to be switched ON or OFF with a checkbox in the setup menu (options or something like that).
That would be a wonderful thing, other hams who work with external amps will certainly be happy too.
I already say thank you and wish you continued success and fun.
best 73 Guenter DK8DX
Postby ramdor » Sun Sep 26, 2021 3:01 pm
Guenter dk8dx wrote:Hello Richie,
Why!?
Hence the request:
We cant prevent the PTT Key rca output on the back of the 7000, not at this time anyway. If you use the OC TX pins you can do exactly what you want.
PD3LK
Postby PD3LK » Sun Sep 26, 2021 3:58 pm
oe3ide wrote:Thanks Richie, 21k3 runs perfect here :-)
Waiting patiently for your Yeasu skin update (xPA) :D
Maybe make the AGC slider light blue when Auto AGC is on? (same as pan sliders?)
thanks in advance Ernst!
NC3Z
Postby NC3Z » Sun Sep 26, 2021 4:19 pm
Guenter, as Ritchie noted you have 7 addition PTT's using the OC Control pins. I use it exactly that way that only the PTT will key my amp but if you use the Tune function it will NOT key the amp.
Here are all the AND OR you can choose. It is super Flexible:
Postby oe3ide » Sun Sep 26, 2021 4:27 pm
Skin is already updated on my website. Here you find the missing stuff: viewtopic.php?f=9&t=3842#p16459
Guenter dk8dx
Postby Guenter dk8dx » Sun Sep 26, 2021 5:38 pm
Hello Gary,
thanks for your help.
Have checked and tested but for me, this way is not working.
My Amp is every time in TX mode when i click the TUNE Button.
Info: My ext amp becomes the PTT from the PTT Output RCA jack on the backside from the Anan.
For me, this way does not the right job hihi.
73 Guenter
NC3Z
Postby NC3Z » Sun Sep 26, 2021 6:46 pm
Guenter, what version of 2.8.11 are you using?
What you are asking for is supported and works great to not key the amp when in TUN.
Postby oe3ide » Sun Sep 26, 2021 6:52 pm
NC3Z wrote:Guenter, what version of 2.8.11 are you using?
But not for "PTT out"... its only possible via OC Output...
PTT out is not software controllable. afaik.
NC3Z
Postby NC3Z » Sun Sep 26, 2021 6:54 pm
Ernst, that is what I told him in my first reply that you need to use the OC Pins for your PTT to make this happen.
DL2LBV
Postby DL2LBV » Sun Sep 26, 2021 7:14 pm
First of all thanks for 21k3, Richie - OC now behaves exactly the way I need it.
@ Günter:
Often it's the little things that we overlook. So it's just an idea and I don't want to offend you. Did you notice that pin 13 on your Expert 1k5 wants to see 12 V in order to prevent transmission?
However, the OC pins of the Anan pull an applied voltage to zero.
So you would have to invert the signal. Connecting Pin 1 - 7 directly to pin 13 on your Expert wouldn't affect anything.
73 Jörg
ANAN 200 D - extra large :) , Protocol 1.915, i7-8550U, 16 GB, win 10, Thetis x64 v. 2.8.11 21k7
