Hey everyone,
Has two way communication between Thetis and the Midi Controller been implemented? I ask because of of the new panels have LED displays like level lights, and saw even one that has some numbers displayed on the large wheels, would be so cool to send the frequency to them. Realize that the displays dont have as many digits, perhaps they could be used for other things as well.
73 de NI0Z
7000DLE MKII Black
Two Way Communication
Re: Two Way Communication
The short answer is "no". There is currently only the ability to control button lighting, and even that is not fully implemented, i.e. if you change a control using MIDI and the lighting codes are properly set up the lights will track the state of the function, but if you change that setting with the mouse it won't change the button light to match.
Thanks! And thanks for all you have done for us! I ended up ordering the Hercules. Is the mapping file available?
73 de NI0Z
7000DLE MKII Black
73 de NI0Z
7000DLE MKII Black
The only mapping file I have available is for a Hercules DJControl Compact. Which Hercules controller did you order?
Hercules DJ DJControl Starlight - ahh, I do see its a little different from yours. I will figure it out!
