RDP whit REMAUD...no VAC-Cable
OZ1CT-Ben
Postby OZ1CT-Ben » Sat Dec 15, 2018 10:06 pm
when I use teamviewer and run HPSDR and let Remaud do the audio + Mic it run ok no problem, but if I try to use RDP then I cant get any VAC-cable in the Remaud-setup ???? but in HPSDR I can see the VAC-cable...anyone there can me a hint what the problem is ???
The reason why I wold like to use RDP is that I have no licens for teamviewer ;-)
OZ1CT-Ben
Re: RDP whit REMAUD...no VAC-Cable
Postby OZ1CT-Ben » Thu Jan 03, 2019 5:45 am
I found the "Error"
you have to setup in the RDP that you will "play audio" from the client and then it works :D
73" Ben
Return to “Remote Operation Over The Internet”
