Microwave transverter issue
FM5GB
Postby FM5GB » Thu Jun 07, 2018 11:42 pm
Hi all !
I am trying to complete a 10 GHz (3 cm) transverter (in fact it is a tranverter chain : 10 GHz-144 MHz-28 MHz).
Unfortunately I am unable to set up tranverters with a higher LO than a little over 2000 MHz in PSDR.
If I attemp to do so PSDR stops working and the main window gets empty (no more panadapter nor waterfall)
Is there a way to solve this issue ? (PSDR v3.4.9. Orion 5.0)
Best 73s Phil FM5GB
DL8LAQ
Re: Microwave transverter issue
Postby DL8LAQ » Tue Jun 19, 2018 4:01 pm
Hi Phil,
this "bug" must be addressed to Doug, W5WC, but maybe he has already seen your message.
73, Norbert - holidays in JM57NH - CT7/DL8LAQ
FM5GB
Postby FM5GB » Sat Aug 11, 2018 7:05 pm
Hi all !
I eventually made it work by downgrading to HPSDRmRx3.4.2. Any try to install a newer version would
lead to the same bug : any transverter receiving frequencie above about 2000 MHz makes the panadapter-waterfall
window erase any info & show only the back ground, so no tuning is possible.
I tried several Orion (200D) firmware from 4.8 up to 5.2 with no luck as long as HPSDRmRx is above 3.4.2. By the way
I must not use a firmware higher than 4.9 in order to use Pure Signal.
I stopped my protocol2 /thetis tests as my 200D gets too unstable under this setup. So I don't know if there is an
issue like this with thetis.
73s Phil FM5GB.
Return to “Transverters”
