2 N00b Questions
wa9vfd
2 N00b Questions
Postby wa9vfd » Fri Apr 27, 2018 11:42 am
RE: PiHPSDR Console
1. Can the console connect to the LAN using the Pi's RJ45?
2. Can the display be split to a second, larger screen?
Thank you.
Re: 2 N00b Questions
Postby w-u-2-o » Fri Apr 27, 2018 12:49 pm
Not only can you attach it to the LAN, you must attach it to at least the radio that way. Of course the radio and the piHPSDR controller can be connected to the entire LAN via a switch.
The pi has an HDMI port to which you can add another monitor. I'm not sure it is accessible in the Apache enclosure (I don't have one, I built my own).
Return to “piHPSDR”
