OLD 7000/8000 Orion MKII Protocol 2 Firmware Topic
ea3aqr
Re: New 7000/8000 Orion MKII Protocol 2 Firmware Topic
Postby ea3aqr » Sat Dec 21, 2019 8:06 am
Some positive SEQ errors, specially when transmiting.
Going back to Pre 1.
NC3Z
Postby NC3Z » Sat Dec 21, 2019 12:05 pm
Well tried Pre7 on my 7000DLE (Classic) and ended up with non stop SEQ errors showing on DDC0, DDC2 and DDC4 and I think most were showing a Seq # of 8.
Went back to Pre4 with no issues.
Postby ramdor » Sat Dec 21, 2019 1:00 pm
Anan 7000dle Mkii (July 2019), radio on its own subnet, that subnet is on its own nic in the pc.
Pre4 : 100-700 lost packets ONLY when radio receives a broadcast DHCP message from a dhcp server. These packets are lost on both Radio->PC and PC->Radio. Receiving station will hear glitch in transmission. It is as if the radio needs to handle the dhcp broadcast (that isnt directed to it) and doing so stops sending ddc data etc.
Pre7: a single 1 packet loss on the radio->pc, every second 1536000 sample rate. Reduced frequency, but single packet loss at 384000. Seemingly endless packet loss using this firmware, even if very minimal on this system. Did not test PC->Radio, all observations are Radio->PC. Power cycle, cooldown/warmup period did not change the loss frequency.
Conclusion, pre7 is not as reliable as pre4 on this hardware. Returning to pre4.
Also, just to add a big thanks to Rick for his ongoing efforts and work with the firmware !
Cheers,
AG5CK
Postby AG5CK » Sun Dec 22, 2019 4:03 pm
My rig did not work with pre 7. No RX and -402dBm on all bands. I could hear the relays clicking when changing bands but no noise floor. Back to pre 1 and all is well.
Puresignal was intermittent with pre 2
pre 4 seems to work OK but has occasional seq errors.
I'm using a 7000 dle mk2 (no internal pc) running Thetis 2.6.8.
Thank you all for the effort put into firmware, software and testing.
Edit: Updated Thetis to 2.6.9 (b6) and so far there have been no seq errors with pre 4
Postby w-u-2-o » Sun Dec 22, 2019 10:27 pm
Great feedback everyone, thank you! :)
iw3fvz
Postby iw3fvz » Thu Dec 26, 2019 8:41 am
Tested pre7 with Thetis 2.6.9 B6
Perfect ... the minimal seq error in tx are vanishid
(from pre4)
Fabio IW3FVZ
iw3fvz
Postby iw3fvz » Thu Dec 26, 2019 2:58 pm
For SEQ problem i suggest to disable "Interrupt mitigation" (if present) in your NIC
Fabio IW3FVZ
Postby w-u-2-o » Thu Dec 26, 2019 3:10 pm
Please see the update in Post #1 above. pre8 is posted, which fixes a problem with erroneous DHCP processing. Please report your results.
For me it works the best of all available in the "preXX" series. There are still small order seq errors, but they are inaudible to me.
dj1yr
Postby dj1yr » Thu Dec 26, 2019 4:53 pm
so far none seq error´s on pre8 with 2.6.9 b6 software
mny thanks for this work!
Postby w-u-2-o » Thu Dec 26, 2019 5:25 pm
Don't thank me, thank Rick N1GP. He is the firmware guru. I'm just the happy messenger :)
ea3aqr
Postby ea3aqr » Thu Dec 26, 2019 7:02 pm
Anan 7000DLE
I need a more in deep testing, but first impression looks promising...
No packet drops or audible glitches like those I had in pre2, 4 or 7.
Thanks for the nice work!
dj1yr
Postby dj1yr » Thu Dec 26, 2019 7:24 pm
w-u-2-o wrote:Don't thank me, thank Rick N1GP. He is the firmware guru. I'm just the happy messenger :)
it was primarily aimed at Rick. :D
NC3Z
Postby NC3Z » Thu Dec 26, 2019 8:15 pm
So far so good with Pre8, been running for a few hours and as stable as Pre4.
7000DLE blue, Thetis 2.6.9b6
AG5CK
Postby AG5CK » Thu Dec 26, 2019 10:49 pm
Pre8 is working well for me and seems to be the best yet. I was getting some random seq errors with pre4 but only when running chrome in the background. This isn't happening with pre8.
I was able to force a couple of seq errors by maxing out the sample rate and fps. Less errors than I was getting with pre4 under those conditions. I think those settings are far beyond what my PC can handle anyway.
7000 dle mk2 (stainless cabinet) running thetis 2.6.9 b6. Not using VAC. Thanks to Rick for all the hard work.
ea3aqr
Postby ea3aqr » Thu Dec 26, 2019 10:56 pm
ea3aqr wrote:Anan 7000DLE
After 1h of local qso just 2 or 3 packet drops (not audible) shown in my VAC monitor.
Outstanding firmware version!
dj1yr
Postby dj1yr » Fri Dec 27, 2019 5:46 pm
tested version pre8 today, this causes problems for me with the RX2.
When I go on the air, you just have a noise level of -30dbm.
Some SEQ errors on TX with activated PSA.
I don't have all these problems with Pre4.
back to pre4.
73´René
Update:
Tested again today, no problem with RX2. :roll:
Sometimes SEQ error with PSA enabled (SEQ -2)
W4WMT
Postby W4WMT » Fri Dec 27, 2019 6:03 pm
I can confirm that the DHCP packet loss anomaly is now gone :-)
Thank you Rick!
Everything else seems to be about the same as pre4. Maybe the seq errors are a bit lower, but time will tell.
Ernie
Postby Ernie » Sat Dec 28, 2019 12:30 pm
Pre8 is working fine here, occasional giant negative seq error, but not very often. Other than that, it works great. 7000DLE Blueface, 2.6.9 b6. W2FMU
W4GM
Postby W4GM » Sat Dec 28, 2019 12:51 pm
Pre8 also working fine here with no issues so far.
nico
Postby nico » Sat Dec 28, 2019 7:14 pm
Pre8 working great with Predistortion and all other functions. However continue having the issue with Diversity reception where RX2 after a while will start peaking at S9+60 and the only way to address the issue is to reboot the Anan 8000
I can replicate the issue and it starts after a few transitions from TX to RX and after adjusting the phase/gain a few times. I have pre-distortion switched on. It is a lot easier to replicate if the noise antenna is connected to RX2
Hope that helps
Nicholas - 2E0GKG
cLicari
Postby cLicari » Sun Dec 29, 2019 5:02 pm
Fyi....
Pre8 with 2.6.9 b6 running like a champ for three days now.
No seq errors running with RX1 and RX2.
CPU usage lowest ever at 4-6% with RX1
Nice job!
Carl
NX5T
Carl Licari
NX5T
nico
Postby nico » Tue Dec 31, 2019 1:14 am
nico wrote:Pre8 working great with Predistortion and all other functions. However continue having the issue with Diversity reception where RX2 after a while will start peaking at S9+60 and the only way to address the issue is to reboot the Anan 8000
Hope that helps
Nicholas - 2E0GKG
Happy to report that it has been working well now. The issue seems to appear again if I keep switching between Receiver 1 or Receiver 2 in the "Receiver Source" Phasing Control Screen. When I just leave it in Rx1+Rx2 it behaves now. I also unchecked the "VFO Sync" box on the main Thetis screen as I noticed that this did also trigger the problem. Otherwise this seems to be the most stable release for me with no other errors or lockups.
Nicholas 2E0GKG
vk6cpu
Postby vk6cpu » Sat Jan 04, 2020 1:31 am
Over 24 hours running pre8 w. v2.6.9(b6) and no reported packet losses.
I upgraded from pre2 - 8. pre2 had an occasional packet loss.
Good work!
All the best
Nigel
VK6CPU
INTEL i9 12900 64.0 GB Ram
iw3fvz
Postby iw3fvz » Mon Jan 06, 2020 8:55 am
one hour contest in RTTY Round whithout SEQ problem.
Thetis 2.6.9b6 . fw 2.0pre8
Dedicated Intel nic interface with this changes:
- Disable IRQ mitigation (Default enabled)
- 384 byte of RX buffer (default 256)
i use this document:
https://downloadcenter.intel.com/downlo ... t-Adapters
in the paragraph "Optimized for quick response and low latency"
Fabio IW3FVZ
cLicari
Postby cLicari » Mon Jan 06, 2020 1:53 pm
iw3fvz wrote:Hello,
I am running a dedicated Intel Gigabit CT card for my 8000DLE with Thetis b6 and P2 2.0 pre8. I have had two lock-ups in over a week of operation and was going to try the two settings changes to the Intel card. I changed the RX buffer but do not see the IRQ Mitigation setting listed in Advanced tab property list. Driver version is 12.17.10.8.
Thx
Carl
NX5T
Carl Licari
NX5T
iw3fvz
Postby iw3fvz » Mon Jan 06, 2020 2:03 pm
cLicari wrote:I am running a dedicated Intel Gigabit CT card for my 8000DLE with Thetis b6 and P2 2.0 pre8. I have had two lock-ups in over a week of operation and was going to try the two settings changes to the Intel card. I changed the RX buffer but do not see the IRQ Mitigation setting listed in Advanced tab property list. Driver version is 12.17.10.8.
Thx
Carl
NX5T
someone call "Interrupt Moderation" search it
Fabio IW3FVZ
cLicari
Postby cLicari » Mon Jan 06, 2020 2:24 pm
Thx
Carl
NX5T
Ah, ok. Found it and disabled. Will see if that helps.
Thx
Carl
Carl Licari
NX5T
dieseldawg
Postby dieseldawg » Mon Jan 20, 2020 7:21 pm
Having frequent seq errors with Pre 8 on my 7000DLE, as with previous versions. New behavior is flatlining of the panadapter display on transmit and total program crash occasionally. Just wanted to include my performance experience here, hope it's useful.
Greg
Postby w-u-2-o » Mon Jan 27, 2020 2:19 pm
See the first post for another update.
AG5CK
Postby AG5CK » Tue Feb 04, 2020 12:34 pm
2.0a has lots of seq errors and the audio drops out intermittently. I went back to pre 8. I'm using Thetis 2.6.9 (1-24-20) and a 7000 dle mk2.
I'm starting to wonder if my PC may not be up to the job. Thetis alone uses 20 to 30% of the CPU. Total CPU use is 30 to 45%.
