coupler to buy
ik7ytt
coupler to buy
Postby ik7ytt » Thu Mar 28, 2019 4:51 pm
i have anan 7000
using ps-a software now. but lookig for a coupler
any suggestions?
i have found this one : https://www.hamradio.com/detail.cfm?pid=H0-015644
in the past i alsofound another one made by an ham in us but don’t remember any more the call/webisite
Or other suggestions? I will use mainly with expert 1,3k (sometime another solid state with 2xblf188)
thanks
Andy ik7ytt
Re: coupler to buy
Postby w-u-2-o » Thu Mar 28, 2019 5:46 pm
If you are not home-brewing your own coupler, there is effectively only a single choice on the market, and you have found it: the Xtronic XDC-4. It comes in a couple of varieties, as you noted you probably want the XDC-4SO which uses SO-239 connectors. It is available from HRO and Gigaparts.
The good news is that it is a very good coupler, even by "lab grade" standards.
With an amplifier capable of greater than 500W output you will also want a 6dB attenuator between the coupled output of the XDC-4 and the radio.
Return to “PureSignal Operations”
