Hi All,
On the Setup/Tests tab, does anyone know how to run the Signal Generator Receive feature. It works fine using the “Noise” mode, but nothing seems to be happening when I try the “Tone” mode.
73, Bryan W4WMT
Signal Generator/ Receive
Re: Signal Generator/ Receive
Hi Bryan,
Far away from the radio right now, so I can't poke at it and see what you are talking about. However, I have used the signal generator feature on transmit. In fact the sweep mode works great for checking filters. But I thought it was a transmit-only function?
