Seeing more bandwidth
AJ5O
Postby AJ5O » Sun Oct 15, 2017 6:19 am
Hey guys, I'm very new to the Apache Labs radio but very familiar with Flex (that's what my dad had and I got quite used to it). I'm not comparing the two or at least not trying to but I do have a question. Is it possible to see more of the band you are monitoring? I can see quite a bit but on the 6300 you can see almost the entire 80 meter band. Is this possible with the Anan 100B and HPSDR? Thanks guys! Matt AJ5O
Re: Seeing more bandwidth
Postby Tony EI7BMB » Sun Oct 15, 2017 11:32 am
Hi Matt, do you have "Limit Stitched receivers" unchecked under hardware config tab ?
Postby w-u-2-o » Sun Oct 15, 2017 1:24 pm
What Tony said, and also in Setup > Audio > Primary you can change the sample rate to 384000 (384KHz). With that change, and using stitched receivers, you can see quite a bit.
However...if you want to use PureSignal you cannot do either. Sample rate must be 192000 or lower, and stitched receivers must be turned off.
AJ5O
Postby AJ5O » Sun Oct 15, 2017 7:03 pm
Thanks guys, the sample rate did the trick. Apparently with the 100B you can't uncheck the stitched receivers box. Oh well. Thanks again.
Return to “PowerSDR mRX”
