Hi All,
Here's a brief post from a weary programmer:
1) I'm only supporting the new protocol aka protocol 2
2) I do have TX support
3) It's working with the Herems-based 10E - tester is Jeff KR3EP who uses SSB and AM
4) I have just received firmware for my 8000DLE and it is working - must have a few days of QSOs before I can declare this as being a 'good' firmware kit.
So there we are - I'll announce ANAN-related updates in this forum and my own Yahoo! group. I'm also building a 'Test For Updates' into the software so you can see what's what without surfing the web.
Toodles,
Current Status
Current Status
sdr-radio.com
Re: Current Status
Great stuff, Simon, thanks for the update!
Re: Current Status
I am also testing for Simon, on my 100D. It's definitely coming along! Below is SDR Console running edge to edge on my triple displays and showing all of 40M.
Re: Current Status
WOW!! looks fabulous Scott
Is anyone testing on the 100 Hermes board?
Charlie
Charlie
Re: Current Status
Will there be a 100 Hermes version or do I need to sell and upgrade?
Re: Current Status
PCRover wrote:Will there be a 100 Hermes version or do I need to sell and upgrade?
Yes, in fact the 100 is essentially the 10E with more power I think. Anyway, all ANAN which run the new protocol (protocol 2) are/will be supported.
sdr-radio.com
Re: Current Status
Just to clarify:
The 100 is the 100W version of the 10. Both use the Hermes 16-bit card.
The 100B is the 100W version of the 10E. Both use the Hermes 14-bit card.
Re: Current Status
Any updates since April ? any ETA ?
Re: Current Status
Ok, I will try this question again 3 months later and see if i can get a reply this time. Any update for release, info or anything?
Re: Current Status
I can't speak for Simon, but...
One of the important requirements to run SDR Console is the Protocol 2 firmware. Unfortunately, there has been little progress on Protocol 2 for nearly a year now. Currently, Protocol 2 is in a state where it may or may not make timing on your particular radio. Some people are lucky and can run Protocol 2 in a stable fashion, others, like your's truly, not so much. I can't get it to run on the 100D or 8000 I have here for more than a few minutes before the radio (firmware) crashes, necessitating a power cycle on the radio to reboot the firmware.
Obviously there may not be a lot of motivation to work on SDR Console Apache Lab support until Protocol 2 is in a little bit better shape.
