Thetis and CW Skimmer
Re: Thetis and CW Skimmer
Postby w-u-2-o » Sun Jan 16, 2022 1:14 pm
Hans,
Lower the audio drive level into Skimmer.
Post your Thetis VAC and Skimmer set up screens for review, if you like, and the setup for whatever you are using to transfer audio data (Muzy VAC or Voicemeeter).
pa1hr
Postby pa1hr » Sun Jan 16, 2022 2:25 pm
TNX for your reply Scott1
Enclosed you will find various screens with the settings.
Thetis 2.8.11.jpg (361.13 KiB) Viewed 2056 times
Thetis VAC1 settings.jpg (80.65 KiB) Viewed 2056 times
VAC4 settings.jpg (77.21 KiB) Viewed 2056 times
CW Skimmer settings.jpg (23.95 KiB) Viewed 2056 times
CW Skimmer settings radio.jpg (21.54 KiB) Viewed 2056 times
73, Hans.
Hans Remeeus (PA0Q/OE3JRC)
https://pa0q.nl
Postby w-u-2-o » Sun Jan 16, 2022 3:41 pm
Not seeing anything wrong, Hans. Try lowering your VAC RX gain setting.
Unfortunately I don't have a license for CW Skimmer so this is a bit of a guess.
pa1hr
Postby pa1hr » Sun Jan 16, 2022 4:36 pm
Hello Scott,
I will try your suggestion.
TNX es 73! Hans PA0Q.
https://pa0q.nl
