K1LSB wrote:Here are my current settings...
Mark--how many under/overflow counts/hour are you seeing with your current settings?
ramdor wrote:Here is the forced flag fix. Also returns fvar instead of the calc'ed var when forced it on. It is somewhat pointless to show the var ratio if it is not being used as it will have no impact on under/overruns.
Holding off putting on main post for now.
21k4 link : https://bit.ly/3kJ9dgK
MD5 - 8CFAFBDC3D800D05E0FB4C22BE97F25C
w9mdb wrote:ramdor wrote:Here is the forced flag fix. Also returns fvar instead of the calc'ed var when forced it on. It is somewhat pointless to show the var ratio if it is not being used as it will have no impact on under/overruns.
BTW...when you post a new version on the 1st page could you also announce it here? Otherwise we don't a topic notification if you just edit it.
w-u-2-o wrote:K1LSB wrote:Here are my current settings...
w-u-2-o wrote:@ramdor
Again, just want to add that having FF Alpha exposed really seems to help for the more normal case of a sound card internal reference. I'm not inclined to mess with anything except for Feedback Gain and FF Alpha. Pending other folk's results, I suspect that the advanced settings can be reduced to only those two values.
ramdor wrote:@mark
I think I would probably go on a hiatus if we decided to pull all that after the nightmare adding it in. lol. Perhaps another tab? [More Advanced Than The Other Advanced]![]()
oe3ide wrote:ramdor wrote:@mark
I would suggest "ludicrous settings"![]()
K1LSB wrote:Scott,
FWIW, my latest VAC1 and Advanced settings appear to eliminate the need to uncheck/recheck the RingBuffer boxes after a Thetis session startup (at least for me).
I don't have any fancy clock hardware. And I've left VAC2 alone for now, focusing on VAC1.
Here are my current settings:
Tony EI7BMB wrote:Thanks for posting your settings Mark. I am testing your advanced settings and I notice right away that the VAR ratios move in a much tighetr range once they settle down so looking really solid here.
w-u-2-o wrote:Mark,
I feel like I need to wait 10-20 minutes before zeroing the counters with your settings though. They take a long time to settle.
w-u-2-o wrote:Summary of results:
Recommendations
- It is would be very good if others could try a revised Feedback Gain of 1E-07 (0.0000001) and FF Alpha of .005 and provide reports on the performance of those changes.
Tony EI7BMB wrote:Will test that starting now Scottw-u-2-o wrote:Summary of results:
Recommendations
w-u-2-o wrote:- It would be very good if others could try a revised Feedback Gain of 1E-07 (0.0000001) and FF Alpha of .005 and provide reports on the performance of those changes.
