DL2XY wrote:Just some Bugs:
Thetis v2.8.11 21d6b,ANAN100, WIN7 X64
- PSform Button Advance: Black Text on black background.
- Setupform/Display/RX2: Band indication is fixed on random Band.
Settings are applied global to all bands.- Console:
Command line option "-datapath:" is broken. If used target path is ignored but "C:\" is used instead.
This leads to database corruption if multiple instances are installed.
Thanks for those Walter.
- the PSForm button. Advanced? not seeing black background here, checked the code, no colour change being made to btnPSAdvanced
- the disp->rx2 has been changed/reworked
- surely if you run mutliple instances and point it all to the same datapath, be it C:\ , D:\foo\ or as default C:\Users\<user>\AppData\Roaming\OpenHPSDR\Thetis then issues could occur at DB write time (last one shut down will be the one you keep). If you want multiple instances like that you'll need to use/also use -dbfilename. I could create a lockfile and check it etc at start up etc I guess, with option to clear it etc if there
Re. the VAC stuff above. Can you put a solution in place into the last tapr 2_8_11 source to calculate those values at runtime?
Cheers, R.
