How to create a new, uniquely named transmit profile?
Taiga
Postby Taiga » Sun Nov 29, 2020 8:07 pm
How does one create a new, uniquely named Transmit profile in Thetis? For example, would like to create a profile named "FT8-20M" for FT8 use on 20 meters.
In Setup-> Transmit one can select a profile in the upper left corner, or add existing profiles by checking the "More Profiles" box in the upper left corner and hitting the "include" button, but don't see a "Create new profile" button.
I realize one could load an additional profile, modify the settings, and save it, but would be stuck with the name of the existing profile.
T.
Re: How to create a new, uniquely named transmit profile?
Postby w-u-2-o » Sun Nov 29, 2020 9:35 pm
Just click "Save" and it will prompt you for a name. Change the name to a new one and you will be good to go.
Taiga
Postby Taiga » Sun Nov 29, 2020 10:36 pm
Thanks Scott!
T
