2.7.0
DG9FDA
Re: 2.7.0
Postby DG9FDA » Sun Jun 28, 2020 2:20 pm
Hello Marcus,
this is the trick! Thank you for this hint! Now I am waiting for a reply to my second problem with the Filter tab...
73 de Georg, DG9FDA
Anan 100D first edition, Thetis v2.10.3.6 x64, Protocol 2 Version 12.1.8
FM5GB
Re: 2.7.0
Postby FM5GB » Mon Jun 29, 2020 12:49 am
Hi Georg,
remember to utilize DDUtil v 3.2.5 and connect your radio to your computer & the amp to your computer (as explained in the amp manual) so you can automatically control your drive level in Thetis by band. So you never overdrive your 1K-FA.
I've been utilizing this procedure since I got my Flex 5000A almost 10 years ago. DDUtil is to be downloaded on k5fr.com. It works for legacy Flex radios and has always been good for Anan radios operated thru PowerSDRmrx or Thetis. Later versions after 3.2.5 do not work being only suitable for Flex signature radios (6000 series).
Maybe you already use this configuration. If not I could give you a hand to fix it if needed.
73s Phil FM5GB
DG9FDA
Re: 2.7.0
Postby DG9FDA » Tue Jun 30, 2020 7:56 am
Thank you Phil, I will try when I find the time...
73 de Georg, DG9FDA
w9mdb
Re: 2.7.0
Postby w9mdb » Sun Jul 26, 2020 8:53 pm
Where is source repository for your code?
Re: 2.7.0
Postby w-u-2-o » Sun Jul 26, 2020 9:37 pm
2.6.9 is here, not sure where 2.7.0 is...
https://github.com/TAPR/OpenHPSDR-Thetis
PD3LK
Re: 2.7.0
Postby PD3LK » Mon Jul 27, 2020 7:06 am
2.7.0a3 is here.... https://www.dropbox.com/s/8ik72kfeqycex ... 3.zip?dl=0
unpack the files into your Thetis installation map. (overwriting the 2.6.9 files)
Don't forget to make a backup before doing this.
73 PD3LK
DH1KLM
Re: 2.7.0
Postby DH1KLM » Mon Jul 27, 2020 10:48 am
From my knowledge, these are the most recent sources.
https://github.com/w5wc/Thetis
Dave30019
Re: 2.7.0
Postby Dave30019 » Tue Aug 25, 2020 11:15 am
Where is the latest firmware for Thetis 2.7a3? Is there a list of fixes the different firmware versions address?
Dave
k4em
NC3Z
Re: 2.7.0
Postby NC3Z » Tue Aug 25, 2020 11:35 am
Dave30019 wrote:Where is the latest firmware for Thetis 2.7a3? Is there a list of fixes the different firmware versions address?
Easiest way to find them is to go to the firmware discussion:
viewtopic.php?f=32&t=3192
rbduck
Re: 2.7.0
Postby rbduck » Wed Aug 26, 2020 7:35 pm
Go to the section Upgrading/Downgrading and read the first topic. It contains links to the firmware areas.
Re: 2.7.0
Postby w-u-2-o » Thu Oct 08, 2020 6:15 pm
All,
Closing this topic. Please continue the conversation in the new Thetis 2.8.6 topic.
