Low sensitivity and low noise floor
vu2mb
Postby vu2mb » Mon Jul 27, 2020 2:56 pm
Hi Friends,
I have recently noticed that my 8000DLE is behaving in a weird way. Its noise floor suddenly goes down to -135 db from -105 and S meter on the same signal to -101 dbm (S4) from -67 dbm (S9+5). It was intermittent few times but today it remained on the bottom. What could be wrong and how to rectify it? Any help would be highly appreciated. I have reset the firmware. I am putting 2 screenshots of the same time with same signal. One is from 8000DLE and another one is from 200D.
200D shows signal at -67 dbm and 8000DLE at -101.
Bhanu
VU2MB
ANAN 8000DLE noise floor and S meter.JPG (164.5 KiB) Viewed 10988 times
ANAN 200D noise floor and S meter.JPG (157.86 KiB) Viewed 10988 times
vu2mb
Re: Low sensitivity and low noise floor
Postby vu2mb » Mon Jul 27, 2020 3:31 pm
Additional points to my last post.
It may be something to do with resettable fuse?
As I was using FT8 and temp was around 48.
It seems not resetting now.
What's the safe temp limit?
Postby w-u-2-o » Mon Jul 27, 2020 4:54 pm
I've been scratching my head all morning on this, but it seems you have a good answer now. Unfortunately I can't tell you what the safe temperature limit is. It looks like you are going to find out for us! :)
My 8000 runs in air conditioning and never over 40W, so it's never really been hot.
vu2mb
Postby vu2mb » Mon Jul 27, 2020 5:41 pm
Dear Scott
Can you please guide me where is this fuse in the radio?
It seems it is defunct or stuck.
I don't have the circuit diagram and it was you who pointed out that resettable fuse may be an issue when a similar issue was cropped up during winters. My radio too runs in ac but temperature shoots up when power is above 60 70W.
Currently I am using a dipole and needs more power when a weak ATNO or New on band comes up or running 40/80.
Would appreciate if you send me a copy of circuit diagram on my email mbsingh@gmail.com
Thank you,
Bhanu
VU2MB
kc2rgw
Postby kc2rgw » Mon Jul 27, 2020 6:03 pm
Just a generic comment. Digital modes even with the on/off cycle of FT8, are high duty cycle. It's much like AM or FM while transmitting.
I don't run any of my 100W rigs above 25W on digital modes. I know people out there say to give it hell on FT8, but I disagree after many years of running keyboard digital modes, PSK, Thor, Olivia, HF and VHF packet, JS8Call etc. The rigs just get too hot for my comfort. Keeping power at 25W or less, I've never cooked a rig and I am a loooong winded rag chewer with overs measured in minutes at a time easily on slower modes.
I offload and use an amplifier if I run digi modes at higher power (with the bands lately, this is often) to keep everything running cool.
Postby w-u-2-o » Mon Jul 27, 2020 6:08 pm
vu2mb wrote:Dear Scott
Unfortunately Apache has requested that the schematics for the 7000 and 8000 series hardware not be publicly posted. You will need to email Apache and request those schematics, which they should send to you.
There is more than one PTC (positive temperature coefficient) device (aka "re-settable fuse") in the unit. They are labeled "F1, F2", etc. on the schematics. You will have to check each one if that's what you think the problem is.
Is your fan running OK? Is the fan vent not blocked?
Postby w-u-2-o » Mon Jul 27, 2020 6:09 pm
There is more than one PTC (positive temperature coefficient) device (aka "re-settable fuse") in the unit. They are labeled "F1","F2", etc. on the schematics. You will have to check each one if that's what you think the problem is.
vu2mb
Postby vu2mb » Mon Jul 27, 2020 6:48 pm
Dear Scott,
Yes the fan is running. Are these PTC's on main Trx board?
Bhanu
vu2mb
Postby vu2mb » Mon Jul 27, 2020 6:50 pm
kc2rgw wrote:Just a generic comment. Digital modes even with the on/off cycle of FT8, are high duty cycle. It's much like AM or FM while transmitting.
I agree with your views.
Bhanu
Postby w-u-2-o » Mon Jul 27, 2020 6:52 pm
There are PTCs on the Orion MKII board, and I think there may be some on the RF amp board as well, but I'm not sure.
Postby K9RX » Tue Jul 28, 2020 11:36 am
I'm confused why you went to suggesting a fuse on this? It looks to me like you have TERRIBLE noise at your location and it simply went away! -101 is a little bit high for me here with a 2.4Khz passband ... and -67 is terrible noise - but it appears like I'm seeing the same signal and not seeing the second signal on the 'high noise' picture ... possibly he was just gone or he is now buried in the noise.
Postby K1LSB » Tue Jul 28, 2020 5:09 pm
Another possibility is that the prefilter is turned off and BCAM is overwhelming the receiver front end.
vu2mb
Postby vu2mb » Wed Jul 29, 2020 3:44 pm
There may be minor time difference of few seconds amongst both screenshots thats why one signal is weak.
Next day i opened the top cover to check the PTC's but before going ahead, I switched on the radio
to realize its just working fine. day before it was in a bad shape even after 12 hours of cooling off !!
Looks like there is some other issue like lose cable or something. Will find out at the next time.
Thank you very much friends to spare time and providing your valuable inputs.
Thinking of putting an extra fan to keep radio cooler.
Bhanu
VU2MB
vu2mb
Postby vu2mb » Thu Jul 30, 2020 10:20 am
While I agree on everything what you said. Just to add that 8000DLE is a 200W radio and rated for 50W on AM and as per specifications its rates for 200W on SSB FM and Digital modes. 1:3 CCS will still result in shooting the temperature unless you are in a cold places like US and Europe. In Places like India 60-70W FT8 active dx will take temp towards 45-48 degrees in a 28 degree ambient room temperature in 15-20 minutes. One solution may be to add another fan to force cooling to this otherwise a war horse.
Bhanu
Postby K9RX » Thu Jul 30, 2020 11:33 am
I never had an issue running the 8000 at 60 - 70W on FT8. Didn't get very warm at all.
But again: you've not addressed my comment - this looks to have no relationship with temperature - or am I missing something? It looks like you have a nearby noise source in one shot (the -67) and that noise source is off/gone in the other.
vu2mb
Postby vu2mb » Thu Jul 30, 2020 2:51 pm
K9RX wrote:I never had an issue running the 8000 at 60 - 70W on FT8. Didn't get very warm at all.
Dear Gary,
Those 2 screen shots are from two different radios. First screenshot is of 8000DLE and second one is from 200D ( just 30 seconds apart) and that's why they have different noise floor levels. 8000DLE when gets hot, its PTC cut off some circuitry and sensitivity goes low. I am not technical so cant explain why? when its cools down it works normally. Second screen shot is from 200D which was okay and thats why it shows strong signal and higher noise floor.
You must be in a cool atmosphere and 8000's LCD may not be showing you 40+ temperature but here in India when outside temperature is around 32 I dont feel like using AC and fan works just fine and 8000DLE gets hot internally but not the outer case as Heat sink is not connected to it.
I have just come back from Seattle 12 days ago after a five months stay and got with me plenty of fair rite ferrites and snap on's to do whatever I can do to reduce or eliminate noise in the shack.
Bhanu
Postby w-u-2-o » Thu Jul 30, 2020 4:57 pm
It could also be a bad solder connection on some component that opens up at hot.
greg
Postby greg » Fri Jul 31, 2020 4:39 pm
Had the same problem on my 8; found intermittent 4 pin molex connector to RF output board. Connector is to ant out pub.
Try wiggling it.
vu2mb
Re: low noise floor
Postby vu2mb » Tue Aug 11, 2020 8:53 pm
This post has nothing to do with the topic I have started few days ago with low sensitivity but it is surely to do with setting of low noise floor on panadapter. In Thetis setup under Display / RX1 Panadapter detector settings of Peak noise floor is much higher and it drops significantly if I choose average while noise level at S meter remains the same and this noise floor falls even more when FFT Size is increased towards 1.465Hz.
This can be seen in the 2 screen shots I am attaching. See the AGC line difference from the noise floor in average settings.
I would like to know if this low noise floor levels improves sensitivity / Dynamic range or something else or the visual change is cosmetic?
Thank you.
Bhanu
VU2MB
Noisefloor with Peak panadapter detector.JPG (156.87 KiB) Viewed 10523 times
Noisefloor with average panadapter detector.JPG (153.98 KiB) Viewed 10523 times
vu2mb
Postby vu2mb » Sat May 08, 2021 6:45 pm
greg wrote:Had the same problem on my 8; found intermittent 4 pin molex connector to RF output board. Connector is to ant out pub.
Try wiggling it.
Hi Greg, Simon and others who responded to help me,
Today I found some time and opened the case of my 8000 after a long gap and checked all connections and cables and found out that 5 PIN ribbon cable that connects J3 on control board to J3 on antenna switching board was the culprit. I have removed it cleaned the connector of any corrosion and connected yet again and my radio is not losing sensitivity at the moment it touches 34 degrees Celcius. ( A -65 dbm signal used to go down to -100+)
initially, it started tripping at 38/39 and then it came down to 34. Today I have tested up to 37 and it was okay.
Whatever it was but seems okay. I am happy again. :D
Was busy purchasing BOM and struggling to find out missing parts of the KM3KM amplifier. He sells assembled kits and also PCB's for $150 as per price on his website yet he charged $200 each from us (me and vu2ded both purchased together) seeing my desperation as I wanted to buy his 98% finished kit and he asked 90+ days for delivery and I requested a max of 70 days and as after 60 days, we were supposed to come back to India from Seattle and I was ready to extend it by 10 more days and he refused. I could not go while my xyl vu3kus took the trip. It was a bad experience buying bare pcb's as his circuit and BOM both incomplete and not giving any tuning, biasing or build data. He says you should understand I can't publish everything. This means he has fear and greed both. Wants to sell the bare PCB's and boost the top line and yet don't want to give any data and complete circuit and other procedures fearing it can be copied. He is actually cheating his PCB buyer but it seems we were the first one outside his circle. Bought a 1900W LDMOS BLF189XRBU and excited to use it pushing around 1400W if successfully able to build it. This is an amazing amplifier and every owner rated it 5 stars on their eHam reviews. Don't know whether these users will be able to repair their amp themselves should the need arises without a complete circuit or it means they have to return to him for often costly repairs.
PS Just found out this guy has supplied us the obsolete version of PCB's and not the one being used now.
Thanks again, Hoping for good times ahead. (My 100d issues remain. Will see it shortly.
Bhanu
VU2MB
