Hello, New Anan owner of a 7000DLE MKII-I7.
Radio Arrived with FW 2.4 and 3.4.9
Static IPs and subnetted.
Upgraded to FW 2.0 and Thetis 2.6.9. Radio works and sounds wonderful. Thetis is very nice and seems very happy on this machine.
I do not get any signals on ADC2 with either software or both protocols. I'm reading frantically but wonder if I am missing something that needs activated to receive on ADC2 I have tried switching ant2 , which is a wellbrook magnetic loop, to ADC2 in the menu as well as activating receiver 2 in the diversity menu and only get flat lines -155db. Is there any way for me to formally test adc2 for proper operation?
THanks in advance for your help and replies.
Todd
7000dle MKII-I7 No signals on ADC2
Todd
GeForce GTX1080
GeForce GTX1080
Re: 7000dle MKII-I7 No signals on ADC2
Hi Todd,
Do you have an antenna plugged into the RX2 port on the back of the 7000dle MKII-I7? I believe RX2 will be deaf unless you do. A quicker check would be to try setting DDC3 to ADC0 and then RX2 will receive on the same antenna as RX1. Not sure as far as hooking up the Wellbrook Loop but I would probably put it on the EXT-1 port but look for someone else who has more experience with that as it applies to the 7000DLE MKII-I7 architecture. It might even be better to plug the Wellbrook into the RX2 port on second thought.
Pretty sure I have that right but I am not in front of my rig at the moment!
Hope it is as simple as that for you!
I do have a Wellbrook receive loop connected to ant 2 . It works on rx2 with adc1 . it does not with adc2.
I will try your other test.. .
Todd
Todd
Todd
GeForce GTX1080
GeForce GTX1080
OK, just to be sure, the ANT-2 connector is a different port than the RX2 connector. Just making sure you are aware of that.
BINGO! No I was not aware of that. Moving the loop to rx2 port is producing beautiful signals. Awesome .. THank you!
Todd
GeForce GTX1080
GeForce GTX1080
Ah, that's great Todd!
Enjoy the new radio, it's a real treat to operate on RX and TX!
Thank you. It is indeed...
I believe I will now try and get it on the air.
Todd
GeForce GTX1080
GeForce GTX1080
Not a firmware topic...moving to the correct sub-forum...
