RX'er 2 glitch on 2.6.8 and .9
GW0DQW
Postby GW0DQW » Wed Feb 12, 2020 9:14 pm
Hello every one ,
I have a peculiar issue that when i select to use my 2nd receiver the windows comes up alright , but the default freq i have set ( 882Khz) is in the setting box but the second receive windows comes up with strange frequencies every time .
I have tried to sort but have failed , any one else had this issue or can give me some assistance please.
Regards
Chris
GW0DQW
Re: RX'er 2 glitch on 2.6.8 and .9
Postby w-u-2-o » Wed Feb 12, 2020 10:17 pm
Seems like a bug, Chris. We'll have to wait for Richie or someone to fix it.
W4WMT
Postby W4WMT » Thu Feb 13, 2020 10:24 am
Unable to reproduce that here, works FB with RX2 set to 882 kHz.
Are you sure it's not a database corruption issue?
GW0DQW
Postby GW0DQW » Thu Feb 13, 2020 10:52 am
Bryan W4WMT wrote:Unable to reproduce that here, works FB with RX2 set to 882 kHz.
Will try that Bryan , thanks for your help , need to look up how to that as never done it .
Thank you .
GW0DQW
Postby GW0DQW » Fri Feb 14, 2020 8:24 pm
Thank you .
Have now reset my database and mostly is OK , like I am not getting freq corruption when bring up RX 2 , Pure Signal is working OK , The only thing i need to sort out now is the PTT is not working off the space bar.
Thank you Bryan and Scott and others for your input .
Best wishes from Wales
Chris GW0DQW
DL8LAQ
Postby DL8LAQ » Fri Feb 14, 2020 8:43 pm
GW0DQW wrote:...
Hi Chris,
try this: viewtopic.php?f=9&t=3303#p10111
