Monitoring of CW
JJ4SDR
Monitoring of CW
Postby JJ4SDR » Tue Nov 14, 2023 2:33 am
This isn't a real big issue, but I would like to understand why this is happening.
VAC used for audio and to hear the side-tone on CW, I am using a pair of head-phones plugged into the front headphone audio port. This works fine, except when I switch from SSB to CW, I will usually have to "tweak" the TX AF number (either up or down by just 1) on the Transmit form. Not sure why that is necessary.
Below, see a partial view from the Transmit form.
TX Monitor.jpg (6.41 KiB) Viewed 4728 times
Thetis v2.10.4.3 x64
Protocol 2 v2.1.18
Re: Monitoring of CW
Postby w-u-2-o » Tue Nov 14, 2023 11:15 am
What happens if you don't tweak it?
JJ4SDR
Postby JJ4SDR » Tue Nov 14, 2023 8:06 pm
No side-tone
Protocol 2 v2.1.18
