PA Profile Banner Showing in Thetis v2.10.3.3
w9ac
Postby w9ac » Tue Nov 07, 2023 8:29 am
I'm not sure if it's by design, but I'm seeing a PA Profile banner inserted into Thetis' display when alternating between screen expand and collapse. At least in my case, it overwrites onto the custom containers. A right-click on the banner opens up the PA settings window, but there's no option to remove it. Screen capture attached.
Thetis v2.10.3.3
Re: PA Profile Banner Showing in Thetis v2.10.3.3
Postby ramdor » Tue Nov 07, 2023 9:37 am
its zorder is probably above the container user control when docked, will fix for 2.10.3.4
you can report bugs over on github which makes things easier to track
https://github.com/ramdor/Thetis/issues/new/choose
w9ac
Postby w9ac » Tue Nov 07, 2023 12:31 pm
ramdor wrote:its zorder is probably above the container user control when docked, will fix for 2.10.3.4
Thanks, Richie.
Postby Joe » Tue Nov 07, 2023 2:15 pm
I have been working a bit with the collapsed view code, the pa profile tag had to be re-located for that view. I placed it at the lower screen view in collapsed. I have not uploaded anything yet to my repo. I worked on a few other items in the collapsed view that may be of interest to Richie but he will need to check it out and correct where necessary, I know and definitely trust his expertise. I mainly use the collapsed view as I like less clutter with slightly used controls. Sorry for the ramble and much thanks to Richie!
73’s
Postby ramdor » Tue Nov 07, 2023 6:51 pm
The label gets relocated when collapsed/expanded are used, however I had left some test code in there to bring label to top which was not needed anymore.
