Is it possible to do a second install of Thetis to run a second radio such as a Hermes lite simultaneously while the 7000 is running on Thetis?
Thank you, Dan KM6CQ
Running 2 Copies of Thetis simultaneously.
Re: Running 2 Copies of Thetis simultaneously.
Hello Dan,
there are several posts about this topic. You can run simultaneously as many Thetis versions and instances with ANAN/HL2/Red Pitaya etc.
as you like, as long as your computer/network can handle it.
You can also use a specific Thetis installation and run it with different databases without the need to install it twice.
There is a datapath command line option for this purpose.
I have collected some links on this topic.
viewtopic.php?f=9&t=4365&p=23369&hilit=datapath#p23369
viewtopic.php?f=9&t=4047#p17870
viewtopic.php?f=9&t=4148&p=19657&hilit=datapath#p19657
viewtopic.php?f=6&t=3245&p=9648&hilit=datapath#p9648
I'm pretty sure you can use these links to get your system working the way you want.
What Sigi said, plenty of info on the forum for just a simple search.
But I run to simultaneous copies, one for my 7000DLE and one for my TRX-Duo., works great.
Hey, thank you guys I appreciate the information. I did multiple searches and perhaps my search terms were not good enough to narrow it down to what you guys provided. Definitely appreciate it.
