CPU Volts and Amp meters not working V 2.9.0.6
KC4MNE
Postby KC4MNE » Fri Jul 01, 2022 12:03 pm
Any idea why CPU Meter is not displaying at all and volt / amp meter does not update. Tried selecting and unselecting volts-amps in settings, but nothing changes. see snip below
Screenshot 2022-07-01 080202.png (5.64 KiB) Viewed 3256 times
DL8LAQ
Re: CPU Volts and Amp meters not working V 2.9.0.6
Postby DL8LAQ » Fri Jul 01, 2022 12:17 pm
No problem here, normal readings at tx (compared to p/s reading), zero amp at rx. Looks ok for me.
w9mdb
Postby w9mdb » Fri Jul 01, 2022 12:21 pm
Which rig? What firmware?
DL8LAQ
Postby DL8LAQ » Fri Jul 01, 2022 12:33 pm
7000DLE, f/w 2.1.18
w9mdb
Postby w9mdb » Fri Jul 01, 2022 12:39 pm
Maybe you need to upgrade the firmware?
2.1.23 here with 7000DLE MKII works OK.
Postby w-u-2-o » Fri Jul 01, 2022 1:52 pm
To clarify the firmware angle: versions beyond 2.1.18 were never formally released past very limited alpha testing, and there have been no changes to voltage and current data handling since 2.1.18. So it most likely is not the firmware.
KC4MNE
Postby KC4MNE » Sat Jul 02, 2022 3:31 am
7000DLE, f/w 2.1.18
tried on other computer and it works fine, so it is not hardware or firmware related, was running v2.9.0.6
uninstalled and erased all files related to thetis, and then reinstalled and started from scratch database and all and it still does not work.
however it did work at one time with V2.9.0.6 on windows 11. going to have to do a clean windows 11 install.
rdwing
Postby rdwing » Fri Jul 22, 2022 8:13 pm
I have a brand new 7000 DLE MK3 delivered a few days ago, running a new fresh install of Thetis 2.9.0.6, and Protocol 1 due to the chip change. Current metering on the radio does not work at all.
Can anyone else with a new Mk3 confirm they also dont have current metering?
There are also other broken things, like unable to switch Tx antennas from the drop down menus, and many other things. Poor showing from Apache.
PD3LK
Postby PD3LK » Sat Jul 23, 2022 5:13 am
As for "other broken things, like unable to switch Tx antennas "
Setup setting General- Ant/Filters-Antenna : uncheck the "Do Not TX" tick boxes (under Antenna 2 and 3.)
W7SS
Postby W7SS » Fri Aug 05, 2022 6:46 pm
7000DLE MKII F/W Ver 2.7
I have the same issue. I'm running Windows 10, Thetis V2.9.0.6
I just upgraded from V 2.8 hoping that would fix the problem.
It did not.
K8EZB
Postby K8EZB » Sat Aug 06, 2022 6:12 pm
Running Thetis 2.9.0.6. Voltage displays correctly; amps always zero. (7000DLE)
Rick
K8EZB
