Can't adjust TX bandwidth using mouse
JJ4SDR
Postby JJ4SDR » Sun May 01, 2022 7:43 pm
I am on Thetis 2.9.06 x64 and attempted to adjust TX bandwidth using my mouse but it didn't pan out. No doubt my settings aren't right.
Two screen-captures below for reference.
Setup Options.jpg (134.32 KiB) Viewed 3884 times
Screen capture May 1.jpg (410.16 KiB) Viewed 3884 times
What am I missing?
JJ
Thetis v2.10.4.3 x64
Protocol 2 v2.1.18
NC3Z
Re: Can't adjust TX bandwidth using mouse
Postby NC3Z » Mon May 02, 2022 1:29 am
Didnt know the mouse wheel could adjust the TX bandwidth. How are you doing that?
Postby ramdor » Mon May 02, 2022 8:58 am
There is no interactive adjustment of the TX transmit bandwidth in the spectrum when in receive. It can only be done using the up/down number controls on the main gui (just above the TX FL button), or in setup in the Transmit tab (Transmit filter).
It can be adjusted with the mouse in the spectrum when in TX, however there are some issues with it which need to be fixed. I have never used it like that personally.
Remember, TX bandwidth is stored per TX profile, so adjustments you make will be temporary unless the TX profile is saved.
JJ4SDR
Postby JJ4SDR » Thu May 05, 2022 2:22 am
Gary, Richie,
Gary:
I can't but a buddy of mine in Florida can and he uses the same exact Thetis version that I do (except that his works in P2, but I don't think that has anything do with this).
Richie:
Ditto above.....my buddy told me that when the mouse cursor morphs into a double arrow line I can drag the TX band-width by clicking the left mouse button and then just drag the bandwidth out. This, just to experiment rather than save anything necessarily. He did it on the fly while we were in contact the other day and I just tried to do the same..... :?
Thanks again for the feedback!
JJ
Protocol 2 v2.1.18
K9CDR
Postby K9CDR » Fri May 06, 2022 7:18 am
JJ4SDR wrote:Gary, Richie,
Gary:
Richie:
JJ
You tried while TX'ing? As Richie states it only works while in TX and even so there apparently are issue. Your screenshot shows you in receive so just wanted to make sure this was clear.
Cory K9CDR
Postby w-u-2-o » Fri May 06, 2022 9:58 am
As Richie wrote, there are some issues with it. I can report that it doesn't work for me here, I.e. I cannot adjust the TX passband graphically when in transmit.
What I normally do is turn on the TXFL lines and then use the TX passband controls to adjust my TX bandwidth until the lines match up with the bandwidth of the others is the QSO.
Postby ramdor » Fri May 06, 2022 10:11 am
yeah it is totally broken atm. I will look at it at some point.
JJ4SDR
Postby JJ4SDR » Mon May 09, 2022 9:39 pm
Cory,
Yes, I did try dragging the TX bandwidth out while in TX mode. Again, my buddy was able to do just that..... :o
Best!
Juha,
Protocol 2 v2.1.18
rbduck
Postby rbduck » Tue May 10, 2022 12:07 am
Maybe I'm premature with my question, When the TX bandwidth is adjusted with the mouse, is the adjusted bandwidth supposed to be retained the next transmissions?
Is this one of the things that's broken?
Postby w-u-2-o » Tue May 10, 2022 12:11 am
IIRC this used to work, and maybe still does in PowerSDR mRX. Doing this was no different than using the numeric controls. It does not currently work in Thetis.
Does that clear up any confusion?
rbduck
Postby rbduck » Tue May 10, 2022 10:41 am
It clears it up for me. Thanks for the information Scott!
JJ4SDR
Postby JJ4SDR » Sat May 14, 2022 7:40 pm
I guess I could always get a MIDI controller and assign the TX bandwidth control to one of the sliders or knobs on the MIDI. Been thinking of going this route any way to put some phyusical wheels,knobs and sliders to the radio.
73 de Juha
Protocol 2 v2.1.18
PD3LK
Postby PD3LK » Sun May 15, 2022 6:55 am
Hi, currently TX low/high filter can only be assigned to a wheel.
I never tried if it works with a knob or slider, but don't be disappointed if it doesn't work.
r/Leon
JJ4SDR
Postby JJ4SDR » Mon May 16, 2022 3:42 pm
Hi Leon,
That's odd. Perhaps it depends on the MIDI controller you are using? Which one do you have?
Best!
Protocol 2 v2.1.18
PD3LK
Postby PD3LK » Thu May 19, 2022 6:47 am
Hi, i'm using a DJControl Compact but this is a Thetis limit/shortcoming, not the controller. (look at the list of useable midi commands in Thetis)
r/Leon
JJ4SDR
Postby JJ4SDR » Thu May 19, 2022 4:26 pm
Got it Leon!
Thanks.
Protocol 2 v2.1.18
