Thetis Skin Installer download
DH1KLM
Postby DH1KLM » Sun Apr 24, 2022 2:12 pm
I have made a Thetis skin installer which includes 42 skins.
The skins were provided by IK3VIG, OE3IDE and W1AEX. All skins are up to date and therefore compatible with Thetis-v2.9.0.6.
The installer is about 34MB in size.
If someone has built a skin themselves and would like to pass it on, I'm happy to include it in the installer.
Feel free to download https://github.com/DH1KLM/Thetis-2.9.0-Red-Pitaya-DH1KLM/releases/download/v2.9.0.6-RED-PITAYA-Edition/OpenHPSDR_Skins_big.exe
rbduck
Re: Thetis Skin Installer download
Postby rbduck » Sun Apr 24, 2022 2:50 pm
I downloaded the installer. Yes all skins loaded and are available! Thank you much for the installer!!!!
K9CDR
Postby K9CDR » Wed Apr 27, 2022 11:32 pm
DH1KLM wrote:I have made a Thetis skin installer which includes 42 skins.
The skins were provided by OE3IDE and W1AEX. All skins are up to date and therefore compatible with Thetis-v2.9.0.6.
Feel free to download https://drive.google.com/file/d/1JMV9Rt8nsP8pawknl-lmZj6SXCEG_ACA/view?usp=sharing
If you want to add this one I put together here I have attached it. If its not up to par, I wont take it personally :)
The K9CDR Blues.zip
(5 MiB) Downloaded 172 times
Cory K9CDR
DH1KLM
Postby DH1KLM » Thu Apr 28, 2022 6:07 am
Thank you Cory,
this is a nice skin. I'll add them to the installer, that's for sure.
PS: Skin already added.
Postby Tony EI7BMB » Thu Apr 28, 2022 11:13 am
I tried to download this but get warning below. When i click on "download anyway" nothing happens. Using Firefox browser. Not a big deal just thought you should know Sigi. Thanks for your work
DH1KLM
Postby DH1KLM » Thu Apr 28, 2022 11:27 am
Hello Tony,
this warning is normal for bigger files which are downloaded from a google drive.
I am using Chrome and "download anyway" works for me without a problem.
Please try to download from https://github.com/DH1KLM/Thetis-2.9.0-Red-Pitaya-DH1KLM/releases/download/v2.9.0.6-RED-PITAYA-Edition/OpenHPSDR_Skins_big.exe
Postby Tony EI7BMB » Thu Apr 28, 2022 11:29 am
That link works fine. Vielen Dank Sigi
dl4zbg
Postby dl4zbg » Sun May 01, 2022 10:42 am
Helped a lot, TNX Sigi
JPPNews73
Re: Thetis Skin Problem
Postby JPPNews73 » Sun May 08, 2022 1:48 pm
Sorry to have to bug you for help, but I can't get the new sliders and features to show up. I uninstalled the previous version of Thetis, rebooted and installed 2.9.06. I then ran the new exe skins install file. It unpacked properly and seemed to run normally, but no luck. I subsequently deleted all skins out of the owner\AppData\Roaming\OpenHPSDR\Skins directory and reran the new exe skins install file. Still no luck. Thetis works just beautifully, but I do not have access to any of the new tools that are supposed to be there, no matter which skin I open. Any suggestions would be greatly appreciated.
73 JP, K5JPP
DL8LAQ
Postby DL8LAQ » Sun May 08, 2022 2:17 pm
JPPNews73 wrote:Sorry to have to bug you for help, but I can't get the new sliders and features to show up. I uninstalled the previous version of Thetis, rebooted and installed 2.9.06. I then ran the new exe skins install file. It unpacked properly and seemed to run normally, but no luck. I subsequently deleted all skins out of the owner\AppData\Roaming\OpenHPSDR\Skins directory and reran the new exe skins install file. Still no luck. Thetis works just beautifully, but I do not have access to any of the new tools that are supposed to be there, no matter which skin I open. Any suggestions would be greatly appreciated.
73 JP, K5JPP
Did you enable the Tune Slider in Transmit Menu?
DH1KLM
Postby DH1KLM » Sun May 08, 2022 2:30 pm
Tried the installer right now 2 times. I could not face a problem.
Please try https://drive.google.com/file/d/1n1-EhJZhcVToJeSTQTTh2y1nUXfv3quR/view?usp=sharing
This one contains only 3 skins. Please empty or delete your skin folder and start the installer. It is a silent installer and has no GUI.
DH1KLM
Postby DH1KLM » Sun May 08, 2022 2:34 pm
DL8LAQ wrote:Did you enable the Tune Slider in Transmit Menu?
Good point.
JPPNews73
Postby JPPNews73 » Sun May 08, 2022 2:37 pm
I figured it was probably something simple like that, and sure enough, all now works as designed, Thanks so much for the quick solution. Your help is greatly appreciated!
va3cxp
Postby va3cxp » Sun May 08, 2022 3:03 pm
Thanks for the installer Sigi!
46flatlander
Postby 46flatlander » Mon May 09, 2022 10:41 am
We're sorry. You can't access this item because it is in violation of our Terms of Service.
Find out more about this topic at the Google Drive Help Center. Google Drive ? Tried two machines ,one Linux and one Win11 any ideas ?
StarLink internet provider. Also both machines run latest Chrome Browser! Thanks
Postby w-u-2-o » Mon May 09, 2022 11:19 am
Don't download it directly to a Google Drive storage location. Download it directly to your PC hard drive.
DH1KLM
Postby DH1KLM » Sat Aug 27, 2022 3:00 pm
I created a new OpenHPSDR_Skins installer that copies the standard skins and s-meter files for the latest Thetis version from Richie to the appropriate directories.
If anyone needs them, here you go. https://github.com/DH1KLM/Thetis-2.9.0. ... _Skins.exe
Also compiled a Thetis installer from Richie's latest sources, which also contains the updated skin installer.
Chipp
Postby Chipp » Sun Aug 28, 2022 6:02 am
Hi Sig, when trying to download the latest installer Windows defender reports the following:
Trojan:Win32/Sabsik.TE.A!ml
This program is dangerous and executes commands from an attacker.
file: C:\Users\Chip\Documents\Thetis\Skins Installer\OpenHPSDR_Skins.exe
I have made three attempts with the same result.
I thought it best to contact you before overriding the quarantine.
W6MY - Chip
DH1KLM
Postby DH1KLM » Sun Aug 28, 2022 6:57 am
Hmm..tested the file in virustotal and a few other online tools as virus free.
Maybe a false positive rating?
I will do some other tests. Thanks for your warning.
w9ac
Postby w9ac » Sun Aug 28, 2022 12:47 pm
Downloads OK here. No warnings using Microsoft Edge.
Chipp
Postby Chipp » Sun Aug 28, 2022 5:02 pm
w9ac wrote:Downloads OK here. No warnings using Microsoft Edge.
It appears to be a false positive when using Firefox.
I can download the file fine on two different computers using Microsoft Edge. Both computers give the false positive with Firefox.
W6MY - Chip
DH1KLM
Postby DH1KLM » Sun Aug 28, 2022 6:32 pm
Strange that my previous skin installer didn't cause this warning message.
Postby K1LSB » Sun Aug 28, 2022 7:02 pm
BitDefender auto-deleted it for me.
