Thetis ctun odd behaviour going from tx to rx
Posted: Tue Jun 08, 2021 7:53 pm
Help appreciated please. I recently ungraded Thetis to v2.8.11 x64 from v2.6.7.
When I enable ctun so the spectrum/waterfall is fixed, then tune off somewhere in the spectrum, then transmit, that new tx frequency becomes the new rx centre frequency when you go back to receive. With the old version I was using this didn't happen, the original centre frequency was always retained which is what I would expect. This rather negates the advantages of ctun feature which I would use all the time. Is there some setting that I need to change to fix this please? I have been through all the releases one by one but everyone after v2.6.7 does the same.
A database reset was suggested but this has not made any difference unfortunately.
Andrew
G4XZL
Andrew
G4XZL
