Hi Folks,
did a new install. All works but spacebar ptt and qwerty-asdfgh up down tuning... I can only type in a frequency....
any hints.
I did not find anything in the manual about switching on/off the keyboard....
HELP ????
Pedro ON7WP
thetis keyboard not working ????
Re: thetis keyboard not working ????
Go to Setup > General > Options > Options-1 and turn on Enable Keyboard Shortcuts.
Go to Setup > Keyboard and make sure things are the way you want them.
Moving this to the correct sub-forum >> Thetis
This bit me too and I pulled my hair out for a while. Thank you for the solution, but why is this (Keyboard Shortcuts) not enabled by default in a fresh install of Thetis? If you're prone to skimming manuals/FAQs you'll see a lot of "use spacebar for PTT" and this not being enabled by default can hang up a new user. Just a suggestion.
