grounding both receivers when operating split
N4XD
Postby N4XD » Mon Apr 19, 2021 11:57 am
Operating an Anan 7000lde with Thetis. When I transmit split, the display shows a HUGE signal when transmitting. Much larger than when operating simplex.
My question is, how do I assure that both receivers are grounded (i.e. not seeing the transmitted signal at their ADC) when operating split?
Right now to get around this perceived problem I've been using xit to do the offset but this is cumbersome.
Ron
N4XD
N4XD
Re: grounding both receivers when operating split
Postby N4XD » Mon Apr 19, 2021 3:23 pm
OK, a bit more detail.
When transmitting on VFO B and listening on VFO A (and VFOB. Both receivers on) the display (set as panafall) for VFO A shows the xmit signal at a high level. However, I have these boxes checked under
General
RX2
Auto mute rx2 on tx
auto mute rx1 on VFOB TX
blank rx2 display on VFOA TX
blank rx1 display on VFOB TX
Seems to me that, with the last two checked nothing should be shown on the display for both rx1 and rx2.
Is this a bug in the firmware?
Ron
N4XD
