Andromeda "Set RX1 Band" buttons for SWL and L/MW not functional
Posted: Fri Jul 31, 2020 7:47 pm
by W1AEX
A little bug report with 2.7.0 a3:
I just noticed that when you are on the HF bands, the HF buttons for the Andromeda "Set RX1 Band" panel work fine for all the bands, including the time standard frequencies, however, clicking on the SWL button brings up all the correct buttons but none of those buttons are hooked into Thetis. When you press on them, the ANAN does not switch to the SWL bands or to the L/MW band.
I'd just like to confirm that others see this.
Re: Andromeda "Set RX1 Band" buttons for SWL and L/MW not functional
Posted: Fri Jul 31, 2020 8:12 pm
by NC3Z
Reboot !
I can confirm the issue you are seeing.
Posted: Sat Aug 01, 2020 1:51 pm
by W9EZ
Yes, maybe reboot. All SWL and HF bands switch just fine here .. THetis 2.6.9
Posted: Sat Aug 01, 2020 2:05 pm
by NC3Z
I was using the same Thetis version as Rob v2.7.0 a3, I upgraded from 2.6.9 a good while ago. Did not realize it had the Andromeda panels also.
Posted: Sat Aug 01, 2020 2:26 pm
by W9EZ
ok Sorry , I completed failed to process the andromeda part. I was selecting on the main GUI
I Should try and upgrade today...
Posted: Sat Aug 01, 2020 3:00 pm
by NC3Z
W9EZ wrote:I Should try and upgrade today...
It will be like a whole new radio you bought!
Posted: Sat Aug 01, 2020 5:28 pm
by laurencebarker
er. yes. I see what you mean.
I've looked at the code and it looks like I haven't written that bit yet - sorry!
Posted: Sat Aug 01, 2020 6:48 pm
by W1AEX
Laurence,
No apology needed! We are all very grateful for all that you (and of course many others) have contributed and for the enjoyment of playing around with the Thetis/Andromeda interface. Thanks for taking a look at this.
