I'm currently running Thetis v2.7.0 (a3).
I used to be able to set the level of the waterfall display by clicking and dragging on the left hand side of the spectrum display.
Has this facility been removed in the latest versions OR have I turned off the option somewhere ?
I've been through all the tabs on setup and so far drawn a blank.
Waterfall level setting
All the best
Nigel
VK6CPU
INTEL i9 12900 64.0 GB Ram
Nigel
VK6CPU
Re: Waterfall level setting
Hi, when i uncheck this box then it doesn't work for me either so i think this is what you are looking for.
73, PD3LK
73, PD3LK
All right you have my attention. Where exactly on the left side of the spectrum display are you clicking and dragging? I was unaware the waterfall display level was adjustable this way. Thank you.
When you drag the spectrum up or down then the waterfall gain can follow this way.
- Waterfall2.png (450.15 KiB) Viewed 3735 times
Perfect! That works. Thanks!
Thanks Leon!
That works for me too!
Problem of my own creation solved!
All the best
Nigel
VK6CPU
Nigel
VK6CPU
