Page 1 of 7
2.7.0
Posted: Sat Mar 07, 2020 4:17 pm
I have spent a couple of hours getting back up to speed with what has been going on with Thetis, which has now moved on up to 2.7.0 as a pre-release active development version.
I will continue to post here my latest compiled exe as a zip including all relevant files that just need to be placed over the top of a working 2.6.9 install. As previously, from time to time my modified source will go back to Doug for a merge.
This version is based form Doug's latest (3/1/20) source, and he has let us know that it includes changes to Andromeda, a whole load of bug fixes (bandstack, thread sleeping and others), a general code tidy up and a change over to a drop down list to select the radio model (in setup).
Please note, this is entirely a work in progress build. Make sure you have updated to final release of 2.6.9 and that release is up and running before updating with the following.
v2.7.0 (3/1/20) UPDATE a3 : https://www.dropbox.com/s/8ik72kfeqycex ... 3.zip?dl=0
Download the zip, right click it, properties and select 'unblock' before you expand it out.
All files in the zip are required to be placed 'over the top' of the files from your 2.6.9 install.
Cheers, RIchie.
All the changes : https://docs.google.com/document/d/1xh4 ... -ibeIBt_k/
Re: 2.7.0
placeholder2
Re: 2.7.0
Posted: Sat Mar 07, 2020 6:52 pm
This might not be recognized by non-engineering types, but every time you use the work "refactored" I get all giggly and happy. I applaud your efforts to continue to slash away at the spaghetti in there! Great stuff!
Cheers!
Re: 2.7.0
Posted: Sat Mar 07, 2020 8:11 pm
by Mike W4OCO
Thanks for all your hard work !
Re: 2.7.0
Posted: Sat Mar 07, 2020 8:52 pm
by W9BHI
Running a 200D .24 P2v1.9
I stalled 2.7.0 everything seems to be working , had to reselect the ADC's for second receiver.
F.Y.I. I noticed the PI (path illustrator) is messed up, only showing text but no paths.
Thanks for all of the hard work!
Don W9BHI :D
Re: 2.7.0
Posted: Sun Mar 08, 2020 3:32 am
by wa1oxt
Refactoring is a disciplined technique for restructuring an existing body of code, altering its internal structure without changing its external behavior. Its heart is a series of small behavior preserving transformations.
Re: 2.7.0
Posted: Sun Mar 08, 2020 11:52 am
by wa1oxt
Got this error on start-this morning when starting 2.7.0 a1 !
error.PNG[/attachment]
oxt
Re: 2.7.0
Posted: Sun Mar 08, 2020 4:07 pm
wa1oxt wrote:Got this error on start-this morning when starting 2.7.0 a1 !
oxt
Gary, can you attach your database.xml please.
Re: 2.7.0
Posted: Sun Mar 08, 2020 4:21 pm
by DL8LAQ
Thanks Richie for the new code.
It's running fine here, no issues so far.
Re: 2.7.0
Posted: Sun Mar 08, 2020 4:24 pm
W9BHI wrote:F.Y.I. I noticed the PI (path illustrator) is messed up, only showing text but no paths.
Don W9BHI :D
Thanks Don, have found this issue.
Re: 2.7.0
Posted: Sun Mar 08, 2020 4:33 pm
by va2na
I give it a try this morning and got 2 issues:
- Wattmeter stay in dBm in Tx ..nor changing to Watt
- spacebar PTT not working anymore ( i have check the keyboard menu, PTT/MOX is checked )
Thank you
Re: 2.7.0
Posted: Sun Mar 08, 2020 5:17 pm
va2na wrote:- Wattmeter stay in dBm in Tx ..nor changing to Watt
1) dBm in Tx for RX1? I dont quite understand how that is happening, because the string 'dBm' only gets used if RX1 is not in TX state. Use the drop down to select meter for TX.
2)
a) make sure you have Setup->General->Options->Options1->Enable Shortcuts enabled
b) make sure you have Setup->Keyboard->SpaceBar Control set to PTT/MOX
Re: 2.7.0
Posted: Sun Mar 08, 2020 5:27 pm
by wa1oxt
Richie ,here ya go.
database.xml[/attachment]
Re: 2.7.0
Posted: Sun Mar 08, 2020 8:33 pm
wa1oxt wrote:Richie ,here ya go.
thanks, issue resolved
Re: 2.7.0
Posted: Sun Mar 08, 2020 8:49 pm
UPDATE - (3/1/20) (a2)
Just a quick update to fix some issues found by you guys.
Please try : See post #1
(3/1/20) (a2)
- fix: path illustrator not working for 100B + 200D radios
- change: change event delayed on comboRadioModel during initialisation. Potential fix for issue reported by wa1oxt and object not set to instance of object inside SetComboPreampForHPSDR
- fix: couple of setupform singleton issues fixed
Re: 2.7.0
Posted: Sun Mar 08, 2020 9:28 pm
by wa1oxt
Tnx Richie ...Thumbs up , solved problem.
Will keep you posted.
gary / wa1oxt
Re: 2.7.0
Posted: Sun Mar 08, 2020 10:06 pm
by W9BHI
Dowloaded a2 software and all is well.
Thanks so much for fixing the issues in such a timely manner.
Keep up the great work :D
Don W9BHI
Re: 2.7.0
Posted: Mon Mar 09, 2020 2:58 am
Just a heads up, it was mentioned in the other 2.7.0 thread that there seemed to be some tx profile issues after the database upgrade. If your mode/whatnot is not being saved as expected, try re-saving the tx profile. I'll take a quick look at this area of code tomorrow to double check the db tx profile migration.
Re: 2.7.0
Posted: Mon Mar 09, 2020 4:37 pm
by cLicari
Richie...
2.7.0 a2 loaded and running great.
DPS/Options/ Filter size for SSB and General/ADC settings didn't carry over. Minor inconvenience.
Fyi... All previous lock-up issues appear to have been resolved with change from Cat 5 Ethernet cable to Cat 6a shielded cable.
Carl
NX5T
Re: 2.7.0
Posted: Mon Mar 09, 2020 6:09 pm
by dl6eat
Spent 2 hours on testing my ANAN 7000 DLE (blue version) and Thetis v270 a2 - also around 10 minutes on my ANAN10 (Hermes Board) - same Thetis version.
All worked fine and stableā€¦..thanks for all your effort and welcome back!
Andy
Re: 2.7.0
Posted: Mon Mar 09, 2020 6:59 pm
by Tony EI7BMB
Hi Richie , I had experienced this but there is no problem with your latest updates.
ramdor wrote:Just a heads up, it was mentioned in the other 2.7.0 thread that there seemed to be some tx profile issues after the database upgrade. If your mode/whatnot is not being saved as expected, try re-saving the tx profile. I'll take a quick look at this area of code tomorrow to double check the db tx profile migration.
Re: 2.7.0
Posted: Tue Mar 10, 2020 12:35 am
by W9BHI
I noticed there is a problem with pure signal.
I am running a 200D with 2.7.0a2 P2 1.9.
The TX ATT. defaults to 31 when transmitting barefoot.
If I turn on PS and turn on the amp, the correcting flashes yellow and the feedback flashes red.
I see that the TX ATT. changes to 15 after you key up with PS on.
The PS used to work fine at TX ATT. was at 15.
Once and a while after several "tesssst and fooouur in the mic, the PS will both go green.
Something has changed.
Don
Re: 2.7.0
Posted: Tue Mar 10, 2020 11:04 am
I have not noticed any change in PureSignal operation here.
Re: 2.7.0
Posted: Tue Mar 10, 2020 12:37 pm
by SA3ATF
Neither do I, everything seems to work perfect.
Thank you so much for the updates Richie :)
Re: 2.7.0
Posted: Tue Mar 10, 2020 3:47 pm
by W9BHI
Brain fart moment, I had lowered my mic gain to get less positive peaks on my REA mod monitor so that made my leveler peaks at -4.
I readjusted the leveler and got the peaks back to 0 and now PS is working FB.
Sorry for crying wolf.
Don W9BHI
Re: 2.7.0
Posted: Tue Mar 10, 2020 5:38 pm
by wa1oxt
Hello Richie ,
Is it possible to repair the Mic slider (Main Gui) and Mic/Gain/Sources (Setup>General>Transmit ) so they operate in VAC1 .
I miss that feature which was operational in MRX.
tnx
gary / wa1oxt
Anan 100D
Thetis 2.7.0 3/1/20 MW0LEG(a2)
PC 2 _ FW 12.1 pre4.
Re: 2.7.0
Posted: Tue Mar 10, 2020 6:06 pm
by wa1oxt
Richie
If you get a chance.....
The Mic gain in the Midi setup is inop
Cannot adjust on my DJ control mp3-e2
Also....
Setup>General>Audio "Allow MOX to override/bypass VAC for Phone
does'nt work when using VOX in VAC.
tnx
oxt
Re: 2.7.0
Posted: Wed Mar 11, 2020 11:40 am
by KX2V
Hello all.
I am getting this error message twice when opening & once when closing Thetis 2.7.
Any help would be greatly appreciated.
Re: 2.7.0
Posted: Wed Mar 11, 2020 12:29 pm
by N2XD
Used 2.7.0 A2 last nite for awhile. All seems to be working correctly. Thanks for all the hard work.
John N2XD
Re: 2.7.0
Posted: Wed Mar 11, 2020 3:15 pm
KX2V wrote:Hello all.
Try changing setting to NONE?
