Thetis and CW Skimmer
w2gs
Re: 2.6.9
Postby w2gs » Sat Dec 28, 2019 9:07 pm
Thetis and CWSkimmer issues
Hi Scott, Samuel and others who have commented
I will post this to the Apache forums. Here is an example of the Thetis/CWSkimmer issue.
1. All the sample rates have been set to 48K. I tried faster sample rates (results were no better) but to remove a lot of variables I used 48K for the rig, VAC and CWS.
2. In order for CWS to track the rig frequency the CWS audio IF has to be set to -600HZ. This is opposite to HPSDR where +600 HZ is used. All previous versions of HPSDR used +600Hz
3. Notice there is a solid line about 600HZ above the selected frequency of 14025.560 on the CWS waterfall. This doesn't appear in HPSDR when using Windows WDM-KS. This artifact will blot out any signal in this area.
4. Looking at both the panadapter and the CWS waterfall you can see that there are five strong signals from 14026KHz to 14030KHz but only one signal at 140295KHZ shows up on the CWS waterfall. This signal doesn't correspond to anything in the Thetis panadapter.
5. On the panadapter waterfall there is the remains of signal about 600Hz above 14025.560. This signal was blotted out by the artifact in CWS that appears at around 14026.2.
I am not sure what's going on here but I would not think there were many changes made in this area of the Thetis software since all this working properly under HPSDR, VAC and CWS. This may be a timing issue or a sample rate problem; I can only speculate. I would be happy to test any changes to the software to resolve the above problems. I know that there may be higher priority issues the developers are working on but sooner or later this should be addressed.
73, George
W2GS
Postby w-u-2-o » Sun Dec 29, 2019 3:27 pm
George,
Please post screen shots of your VAC setup and your CW Skimmer setup pages.
NN3RP
Re: Thetis and CW Skimmer
Postby NN3RP » Tue Dec 31, 2019 11:33 am
My CWS / Thetis works without the offending line / bar across as mentioned here. The only issue that I am having is displaying the frequency (CAT settings) on CWS, however. I have tried Kenwoood, TS2000, PowerSDR with COM Pairs to no avail. Once I can have it display, I will confirm frequency accuracy on both Anan 7000dle MKII I7 and CWS.
Note: I do remember having this working perfectly with Thetis a while ago. Despite having screen shots of the past settings, I cannot make it display so far.
Never Give In, Never Give Up!
Rafael / NN3RP
Nation's Capital USA
w2gs
Postby w2gs » Wed Jan 01, 2020 9:30 pm
With the help of Greg KC8IIR a solution was found to the unwanted artifact and missing signal problem. The VAC settings that work with HPSDR don't work properly with Thetis. Also CWSkimer settings had to be changed to reverse the waterfall display. I have attached the settings that work with my Anan 8000.
Two addition files are in a following post showing the settings of CWS. Unfortunately I must have reached attachment limit. It would have been nice to have all this information in one post but it should follow this one.
73, George
W2GS
Thetis Audio VAC tab.PNG (186.95 KiB) Viewed 18886 times
Thetis VAC.PNG (185.8 KiB) Viewed 18886 times
w2gs
Postby w2gs » Wed Jan 01, 2020 9:34 pm
Attached are the Radio and Audio tab from CWSkimmer that are need to completely resolve the subject problem. See the previous post for VAC and Thetis settings.
73, George
W2GS
Thetis CWS Radio tab.PNG (38.66 KiB) Viewed 18886 times
Thetis CWS Audio tab.PNG (40.09 KiB) Viewed 18886 times
Postby w-u-2-o » Wed Jan 01, 2020 9:45 pm
Thanks for posting this, George.
w9ac
Postby w9ac » Wed Jan 01, 2020 9:54 pm
In the Skimmer setup menu, I only see sound card options for MME and WDM. Does this mean ASIO drivers won't work with Skimmer? I only see transmit profiles in Thetis so I'm assuming that a separate sound card profile for Skimmer isn't possible? Yikes, I would hate to go back to using VAC for CW Skimmer.
w2gs
Postby w2gs » Thu Jan 02, 2020 1:38 am
Paul,
For skimmer to work with PSDR/HPSDR/Thetis you need I/Q quadrature signals. I don't think ASIO provides that type of signal (could be wrong). The only options in skimmer are MME or WDM. If are using a non SDR like an ICOM etc. skimmer will use direct audio (WDM) but the waterfall bandwidth is limited to about 3KHZ across the waterfall. I haven't used a conventional radio for a long time but I remember the performance was not very good. I use a USB interface for SSB and just switch between ASIO and WDM. Both HPSDR and Thetis handle the switching without any problems.
73, George
W2GS
Postby w-u-2-o » Thu Jan 02, 2020 1:07 pm
George is absolutely correct. ASIO, and Voicemeeter, is, unfortunately, not a good solution for moving IQ data via the VAC interface. You will have to resort good old Muzy VAC.
NN3RP
Postby NN3RP » Thu Jan 02, 2020 1:57 pm
To all Happy New Year!
George, can you possibly post the settings for CAT in CWS (OmniRig) / Thetis?
I am using VSPE for port creation and I can manage to interface Thetis to other software, i.e., N1MM, WSJTX, etc. but not using OmniRig.
Rafael / NN3RP
NN3RP
Postby NN3RP » Thu Jan 02, 2020 10:36 pm
I have figured out why OmnyRig's CAT cannot connect to CWSkimmer so that it displays Thetis frequency read out. All it takes is the creation of a Connector and a Splitter. Additional Pairs can be added if needed for TX, i.e., PTT or CW. I used the VSPE eulation software.
In the sample picture attached, I set COM20 as the Connector. This port is set in Thetis / Setup / CAT. I also created a Split set COM20 <=> COM10. COM10 is the set that is used in all of the software, i.e., CWSkimmer, N1MM, etc.
The following picture will demonstrated all of the settings. I hope this can assist others in getting CWS to display the Thetis frequency and be dead-on spot when clicking either waterfall.
73s
Rafael / NN3RP
Postby K9RX » Fri Jan 03, 2020 1:37 pm
NN3RP (no name at the end) ... can you provide links for these pictures please? - the pertinent ones (not sure why there is a cable/coin in the one) ... these are not readable as is.
thanks
NN3RP
Postby NN3RP » Fri Jan 03, 2020 1:45 pm
Hi, Gary and good morning all!
The system does not allow but only three (3) pics in one shot? So I took a snapshot of all of the snapshots and the penny and cable is part of the desktop...hihi.
I will try and see if I can post pics in several posts....or link to a Word document that I've created...stay tuned!
Rafael / NN3RP
Rafael / NN3RP
NN3RP
Postby NN3RP » Fri Jan 03, 2020 3:10 pm
As promise, here is a Word document with the main pics and notations:
Thetis Setup with Skimmer.docx
(462.8 KiB) Downloaded 432 times
or...here is a OneDrive link showing all of the snapshots taken in the production.
https://1drv.ms/u/s!Al_5NCnHQyKatBsSWk_zb1StQhRR?e=OryL47
Rafael / NN3RP
w2gs
Postby w2gs » Fri Jan 03, 2020 3:32 pm
Here are my Omni Rig settings in CWSkimmer.
73, George
W2GS
Thetis CWS Omnirig.PNG (23.68 KiB) Viewed 18734 times
NN3RP
Postby NN3RP » Thu May 14, 2020 5:09 pm
Helmut, good day to you and yours.
Looks like something has too much audio gain.
I reopened my file and followed the pictures to redo each of the steps one by one. I do not see that blurriness on the decoding window after I launched Thetis / CW skimmer. Unable to replicate.
My version of the VAC is 4.15...Not able to tell what / if any difference as I don't have the latest.
Rafael / NN3RP
Postby w-u-2-o » Thu May 14, 2020 6:30 pm
Try changing RX gain in Setup > Audio > VAC1.
NN3RP
Postby NN3RP » Thu May 14, 2020 7:10 pm
...try using only one Rx instead or RX2 and see if there is any difference.
Rafael / NN3RP
Postby w-u-2-o » Thu May 14, 2020 9:01 pm
I set this up once upon a time during my eval. period with CW Skimmer. Since it's not a tool I'll ever use unfortunately I can no longer do this again to help out as the trial period is expired. However I don't remember it being that difficult. I seem to remember you want to set it VAC IQ mode, 192KHz sample rate, and vaguely remember using the Softrock IQ setting in CW Skimmer. It worked great and you could monitor a full 192KHz.
I recommend you set all your Windows audio levels to 100% (aka 0dB). Similarly, if you use Voicemeeter, set all those levels to 0dB. Only use the VAC RX gain setting to adjust gain.
Postby w-u-2-o » Sat May 16, 2020 4:28 pm
If someone knows how to generate another trial period in CW Skimmer (short of reformatting my hard drive) I'd be happy to take a look at this.
NN3RP
Postby NN3RP » Sat May 16, 2020 5:42 pm
Maybe modifying the Registry?
Rafael / NN3RP
NN3RP
Postby NN3RP » Sat May 16, 2020 5:45 pm
BTW, Helmut. Why are you mentioning / using SDR Console? In my setup configuration I am only using Thetis!!! Try not using SDR Console altogether.
Helmut wrote:Hello Om´s,
I think I found the reason, why there are so much artifacts - on Simon´s SDR-Console Site:
The spectrum and Waterfall in SDR Console use DirectX graphics, CW Skimmer uses GDI / GDI+. It is possible that the two do not behave together well causing the SDR Console waterfall to stagger.
Some her using Thetis with GDI or DirectX. I am using DirectX and the CWSkimmer GDI - it may work using both in GDI Mode but does not work when Thetis is on DirectX.
There is (since quite a long time) the hope, that the CWSkimmer will be updated to a more modern code.
@ Scott: I found the slider which does reduce the IQ-Stream, it is not in Thetis, it is in Win10 the AUDIO (german version Sound) Setup where the sampling rate can be changed. When between 20-30 % the stream stops completely and up it does not change the artifacts.
Sorry - tested now for 1 hour with different settings but no change on the artifacts - seems to have nothing to do with DirectX and GDI settings in Thetis
I think - I give up - on this adventure !
VY 73
Helmut dl9eri / oe9eri
Rafael / NN3RP
NN3RP
Postby NN3RP » Sat May 16, 2020 7:45 pm
I probably was using that older version at the time of the writing....now is v2.7.0 (3/1/20) MW0LGE (a3)
thetis version.gif (6.3 KiB) Viewed 16488 times
Rafael / NN3RP
NN3RP
Postby NN3RP » Sat May 16, 2020 10:03 pm
Hi Helmut 40M is busy for sure today:
Here is a pic:
Rafael / NN3RP
NN3RP
Postby NN3RP » Sun May 17, 2020 6:53 pm
Helmut, we have practically the same setup My Anan 7000dle MKII is the newest version with the PC incorporated. CW skimmer is the same version. Thetis and Firmware is the same. Same VSPE (paid). OmniRig is a bit different version as I have 1.16 but I doubt this will make a difference. My VAC is version 4.15.
If you are willing, I volunteer to review your settings via remote access. It is better to see what you are seeing. Since we are now teleworking, I have plenty of time (don't tell them). Do you have Internet remote software, i.e. Zoom, ChromeRemote, TeamViewer?
Rafael / NN3RP
Postby w-u-2-o » Sun May 17, 2020 8:56 pm
Don't look for Zebras (e.g. network problems) when horses will do. This is almost certainly an audio setup problem (and the audio doesn't flow over the network, only between Thetis and Skimmer).
Post screenshots of the following:
Thetis VAC1 screen
Muzy VAC control panel
The Windows sound control panel Advanced Tab for each Muzy VAC device
Skimmer setup screen
You can attach the screenshots to your post and mark them to display "inline" using the Attachments tab below the main forum editor window when writing your post.
NN3RP
Postby NN3RP » Mon May 18, 2020 1:16 pm
Helmut, you might want to open a support case:
https://vac.muzychenko.net/en/support.htm
I am sorry but I cannot do run a test on my working system. I could try on another system that has the exact same software with the newest version of VAC. I will post when I am done.
Rafael / NN3RP
Postby w-u-2-o » Mon May 18, 2020 2:48 pm
Helmut,
Have you considered using Voicemeeter Potato (VMP) instead of Muzy VAC? VMP is free. Both app's can be installed simultaneously without interfering with each other.
VMP acts as a virtual mixing console. You have full control over levels with full audio level metering. There is a separate VMP topic in the forum here: viewtopic.php?f=13&t=2936
Postby w-u-2-o » Tue May 19, 2020 11:13 am
Helmut wrote:Scott: I have VMB in use but do you think VMP can have an IQ-Datastream ? Normal Audio streams for CWSKimmer are only 3 KHz for decoding, on IQ-streams you can decode all CW in the whole CW-portion of our bands - that is what I am looking for....
I've never done it personally. My trial ran out on Skimmer before I could. And since I'm not really a CW operator and was just looking at it for other people I never bought a license.
However, Conrad, PA5Y did get IQ to work at 96KHz with VMP. There is a lengthy topic here. There's no reason, therefore, that it shouldn't work at 192KHz.
Also, when I was working with Skimmer I did not have to use Omnirig to communicate with it. I was able to simply connect it directly to PowerSDR (or Thetis) with a virtual serial port pair.
pa1hr
Postby pa1hr » Sun Jan 16, 2022 12:13 pm
What could be the reason of these overshoots in CW Skimmer? It looks like IMD.
TNX and 73, Hans.
ANAN-7000DLE MkII black
Thetis 2.8.11
VAC4
Hans Remeeus (PA0Q/OE3JRC)
https://pa0q.nl
