So under the CAT tab in settings there is a spot to put a UDP port for N1MM. Is there a way for Thetis to send out UDP Freq info in the N1MM require format?
I currently use the CAT port to DXLabs Commander in order to send UDP freq info to my HF Auto, but if I could eliminate 1 step (Commander).....
CAT UDP
Re: CAT UDP
Hi Gary,
The 'Focus Master' feature in Thetis monitors the UDP packets from N1MM. It does not send out packets.
To send out formatted packets would require additional changes to Thetis.
Doug
W5WC
Doug
W5WC
