K2GX wrote:Hi Richie,
Just tested b4 – the palette setting LinAuto (Display>RX1>Waterfall>Palette) Waterfall displays no data (White), with Driver Engine running DirectX.
thanks, fixed. Issue with min/max states, and rgba order.
While I now have no doubt it does not do what I think it doesramdor wrote:w-u-2-o wrote:Is the "Wheel Tunes Outside Spectral" problem fixed in b4?
Cheers!
not sure there was anything to fix Scott. See : viewtopic.php?f=9&p=9467&sid=b515f3c44a483a638e52b36a0bd62b38#p9435
It doesn't do what you think it does.
w-u-2-o wrote:Please pardon a rare bout of cluelessness on my part
np2g wrote:On collapsed2snap.PNG1snap.PNG
Looks like part of the 4 is missing ??
I am such a dolt! I can't believe I didn't remember that. That really was a stupid question. Very embarrassed I am!ramdor wrote:Hi Scott,
It just prevents you from using mousewheel to tune when the mouse pointer is not over the spectral display. ie, mouse wheel works outside spectral area if enabled. It was put in to prevent accidental scrolling of frequency if you missed some other slider slightly, such as drive, agc gain etc etc etc. It is explained in post above showing blue/red overlay image. No idea why that link didnt take you to the post. I will link again viewtopic.php?f=9&t=3182&start=330#p9435
CTUN behavior I understoodAnyhoo...when CTUN is enabled...
ramdor wrote:DO2ZA Erwin wrote:Hi all and Ritchie,
at first 2.6.9 b2 is running perfekt here, many thanks !!
Right Click on CPU in Status-Bar ?? No funktion here??
Sometimes I have a problem to save my Setting in the Database, here it is on DSP - Options, the Filter-Type. Sometimes it is saved, some
time not?? (B1 Version).
73 Erwin
cpu status bar change as not yet been released. Saving issues, probably related to TX profile, save the TX profile and should be ok?
W2SDR wrote:I have been noticing with the last few releases that when I'm on AM for a while and use the space bar for the PTT for a QSO, when I switch to SSB and turn VOX on the VOX does not work. The only way I can get Vox to start working agn is to restart the software. Then all is well. I am using VAC with a USB mic pre for my mic audio.
Frank, W2SDR
wa1oxt wrote:Request....
Is it possible to have a vertical gain adjustment included within the "Scope" and "Scope2" feature on the main gui ?
Also , does anyone have a clue how to get the playback feature working when in VAC ?
tnx
garyradio / wa1oxt
K9RX wrote:Tom, KA1GXR, not sure if this is the same thing but it sounds similar at least in part ... check out my post and the thread here:
viewtopic.php?f=6&t=3167&p=8668#p8668
this is regarding an issue where there is RF present that causes preamps to blow and false "HIGH SWR" to be seen ...
KA1GXR wrote:Greetings all:
Using Thetis 2.69 B1 or B5 on my 200D while testing for RF leaking into Ant 2 while Tx assigned to Ant 1 Found the following:
If QSK is turned on Tx power goes to whichever RX antenna is selected 1,2, or 3 even with Ant 1 checked as TX and check boxes
under ANT 2 and 3 for do not transmit on those antennas. I also See the previously reported leakage during non QSK transmit to
Ant 2, About -10 db to plus 5 db during random keying spikes in CW mode. Lengthening Keyup delays does not stop the spike. Not
looking for solution to that here. See Similiar spike on my 8000 DLE also.
Only curious if tx during QSK is normal. Tested on 2nd desktop PC also with same results so I do not suspect corrupted database.
Tom
KA1GXR
VA2EY wrote:Hi Richie
TX Gain (dB) in Wave menu no longer works with version 2.6.9 b5_2
Michel
