2.6.8
Re: 2.6.8
Postby ramdor » Mon Nov 04, 2019 10:27 am
Thanks for info. Forwarded to Doug. It looks like msi contains the file.
Re: 2.6.8
Postby Tony EI7BMB » Mon Nov 04, 2019 11:04 am
Thanks again Richie , yeah that Sun SDR software looks cool
ik7ytt
Re: 2.6.8
Postby ik7ytt » Mon Nov 04, 2019 11:35 am
Dear Richie
ik7ytt wrote:i'm noticing since update D some problems with PSA.
is not working all the time. even if all other setting are unchanged..
Can you be more specific? can you reproduce the issue? does it happen in 'c' versions. Does it happen in 2.6.7? What radio are you using? etc etc
Regarding PS-a issue i don't remember exactly since when.
The problem is that the 2-tone test in linearity menu don't give me the Correction, greed feedback all the times
then when i go in Tx sometime i get the greed lights for the corrections sometime, disappears. is random , is with or withoutthe use of any PA,means any power level and is on every band/antenna i have
i'm trying to update following the sequence of your updates releases, because i saw sometimes have only thetis.exe file sometimes also others.
so i'm sure i made all the steps and non loosing any files.
the problem is to go back....i don't recall exactly with one was perfectly working and every time i cancel the old zip files.
My opinion for future updates:
1) when use split i think need also be seen on the panadapter . it is noticeable only when trasmitting only if activated the multi rx function.
2) C-tune : still don't understand why is not possible to cancel this button and be able to move panadapter or tune according to the mouse selection as all other sdr software.
3) Collapse/Expand view? why spend time to develope 2 different view with missing of clear functions (user friendly) in both? there is the rx2 that is important and still not devoped in both view.
all other technical updates seams works fine.
thanks anyway for the efforts
- spit can be seen in certain modes by using TX FL button (the certain modes caveat needs investigating)
NOTED THANKS. IN THIS WAY WORKS FOR SURE,, BUT THE TX-FIL BUTTOM SHUOLD BE USED FOR SHOWING THE TX-FILTER RANGE NOT THE SPLIT LOCATION. FOR THIS I WAS ASKING IF MAY BE THERE WAS SPACE TO IMPROVE THIS ALSO
- you can drag the panadaptor in ctun mode by using top area of spectrum area, like top 20 pixels or something, but yes, I agree, something needs to be tidied up with CTUN/centre locked modes
LIKE YOU SAY IS WORKING BUT IS NOT OPTIMAL
... and the final point,
It is open source, people can add/do what they want. I started looking at this by changing the RX1 meter width for a friend, and a couple of other small changes. That snowballed into fixing quite a few issues, adding RX2 panafall (somewhat shoehorned in), adding DirectX engine, Manual Notch GUI, etc.
My whole thought process is I want a better experience for myself, a bonus that other people might like the changes I make, and as a user of ExpertSDR2 from ExpertElectronics I get to see a very polished piece of software. Slowly perhaps with changes Thetis might get steered toward something that doesn't resemble what it is now, but it all takes time.
Also, remember, there is nothing stopping anyone having a play around with VisualStudio 2019 (its free) and changing Thetis for the better. Even 'non programmers' can follow on line courses and learn.
OF COURSE SINCE YOU STARTED TO UPDATE FREQUENTLY THIS SOFTWARE START TO BEGIN INTERESTING. SDR RTX I BASED ON THE SOFTWARE IF NOT DEVELOPED THE RTX ITSELF IS NOT USEFULL. YOUR EFFORTS ARE GREATS, I WAS JUST SAYING THAT WORKING ON 2 DIFFERENT WIEVS MAY BE WAS NOT OPTIMIZATION OF THE WORKING TIME, DOUBLING THE JOB.
I SEE YOU VIDEO IN OTHER POST AND THAT SEAMS TO BE INTERESTING , SO LOOKIS LIKE YOU ARE ALREADY THINKING FURTHER AND IN RIGHT DIRECTION
THANKS Andy ik7ytt
Bryan W4WMT
Re: 2.6.8
Postby Bryan W4WMT » Mon Nov 04, 2019 11:37 am
Looks like someone (maybe Doug?) in the past had already begun trying to exploit the powerful "rxa" capabilities in the ChannelMaster (see rxa.cs). Very interesting concept: each DDC having its own undocked panadapter and controls.
ea3aqr
Re: 2.6.8
Postby ea3aqr » Mon Nov 04, 2019 11:40 am
ramdor wrote:Hi all,
e2 is the end of this iteration and everything is with Doug so expect and update/release at some point.
So with that in mind, let the games begin :D
This is going to take a while...... loads and loads of the structure to change. Lets see how far along it is by the end of the year.
WoooooooooooooooooooooooW!!!! :o
NC3Z
Re: 2.6.8
Postby NC3Z » Mon Nov 04, 2019 12:16 pm
Way too cool Ritchie! We really appreciate all your work and talent to do this!
W3MMR
Re: 2.6.8
Postby W3MMR » Mon Nov 04, 2019 12:20 pm
Is anyone else experiencing issues with the "Special Panafall Mode" feature in the "Spot" tab? It hasn't worked for me in gosh, many many updates. Not that its a big deal, I was just curious if I was the only one. Its, in my opinion, a great idea if you use the gray line map a lot.
Perry
W3MMR
Studio "A" - Anan 200D, P2 1.9, Thetis 2.6.9c3, Dell XPS 8700 i7-4770k, Samsung EVO 860 SSD, Nvidia GeForce GTX1050ti, 16GB RAM, Shure SM7B, AL80BX
Re: 2.6.8
Postby ramdor » Mon Nov 04, 2019 12:20 pm
Bryan W4WMT wrote:Hi Richie,
yes, Doug told me about the rxa class and related panDisplay. I was just having a play around with dockpanelsuit (WeifenLuo.WinFormsUI.Docking) to see what it could/couldn't do and if there were any issues with directX hwnd render. Also, I don't really fancy implementing all that docking stuff.
Not sure what it easier to do yet, change existing Theits, or build new project from ground up, and pull required parts in. One thing is for certain, all the old GDI+ code is probably going to be ditched.
Re: 2.6.8
Postby ramdor » Mon Nov 04, 2019 12:26 pm
W3MMR wrote:Is anyone else experiencing issues with the "Special Panafall Mode" feature in the "Spot" tab? It hasn't worked for me in gosh, many many updates. Not that its a big deal, I was just curious if I was the only one. Its, in my opinion, a great idea if you use the gray line map a lot.
Perry
W3MMR
Yeah sorry Perry, it isn't in there anymore, the whole block of code is commented out at the moment.
When the centre of the panafall can be dragged up/down, then implementing that special mode will so much easier + better :)
ULTIMAX
Re: 2.6.8
Postby ULTIMAX » Mon Nov 04, 2019 12:53 pm
Hello Richie,
I have a question for you , last night doing some skin work I encounter a problem , I close the software and after I try to re-started the opening window came in started loading until the green bar got to 1/2 way and it disappear and the radio won't show, anyway after many attempts I decided to remove Thetis and re-loaded, now here's my question to you to apply all the updates after the start up of 2.6.8 b.c.d.e do I have load them one by one you know b.c.d.e blocks or just by doing the last e1 and then e2 will get back to where I was ??
BTW, I love the up coming features and we appreciated all your hard work,,,thanks !!
Albert
N3YV
Re: 2.6.8
Postby ramdor » Mon Nov 04, 2019 1:23 pm
Albert,
v2.6.8 has been released, so probably best to grab a new install. This will give you a new baseline. That release is everything up to and including 2.6.8(e2). https://github.com/TAPR/OpenHPSDR-Theti ... tag/v2.6.8
I am now working on 2.6.9(a1) which moves on from that install above. I will probably release all dll's from this point on with any changes, it just makes it easier.
ULTIMAX
Re: 2.6.8
Postby ULTIMAX » Mon Nov 04, 2019 1:56 pm
Thank you very much Richie, is a done deal
good luck with the upcoming 2.6.9 I know we're for a treat
Maybe some better looking analog meters like on that Russian radio
don't hate me :lol: I wont push my luck
Thank you My brother
Re: 2.6.8
Postby w-u-2-o » Mon Nov 04, 2019 2:42 pm
I just performed a clean install from the TAPR Git repo. (uninstalled all previous versions of Thetis, then ran the installer). I'm assuming this is e2, the window title only says "2.6.8
I immediately ran into a big problem: during TX there is no display of the spectrum being received on ADC0 with DUP ON, and there is no MON audio output under any conditions. I'm probably going to have to go back to my backup copy of d2 (which is was as far as I had gotten last week).
Re: 2.6.8
Postby ramdor » Mon Nov 04, 2019 2:46 pm
yes, Doug wrapped up e2 and released it. No other reports of that problem on ADC0. No changes to any of that code either in all versions not sure what is going on there.
I will do a clean install from tapr distro, just to check. brb as they say.
Re: 2.6.8
Postby ramdor » Mon Nov 04, 2019 3:03 pm
total fresh install
1) backed wdspWisdom00 file from %appdata%\OpenHPSDR\Thetis
2) uninstalled via add/remove programs
3) deleted %appdata%\OpenHPSDR
4) re-installed
5) copied back wisdom file
6) ran Thetis up, selected, 7000dle, UK, fixed IP, directx
7) shut it down
8) restarted, picked fwd swr, set tx tune power to 14, ok on setup form
9) tune 80m
10) mox 80m
11) mon then mox80
all ok
w2ner
Re: 2.6.8
Postby w2ner » Mon Nov 04, 2019 4:01 pm
WOW, I'm loving that!!!
Re: 2.6.8
Postby w-u-2-o » Mon Nov 04, 2019 5:42 pm
OK, problem solved: I had to rebuild the database from scratch :( :( :(
90% done, just need to do my custom filter presets, import the MIDI setup, check VAC2, and try it out on the air :)
K0MO
Re: 2.6.8
Postby K0MO » Mon Nov 04, 2019 7:56 pm
Glad to heard you solved the issue. To be safe, I always backup both C:\Program Files (x86)\OpenHPSDR\Thetis and C:\Users\User\AppData\Roaming\OpenHPSDR directories, including exporting the database+wdspWisdom00 files, before doing any updates or changes to the program.
Other than the PureSignal firmware issue, my Anan 100B has been working flawlessly.
I can even run Thetis remotely through my wifi network at maximum speeds with my Surface Pro 6 tablet :D
Manny K0MO
Manny K0MO
W2SDR
Re: 2.6.8
Postby W2SDR » Mon Nov 04, 2019 8:45 pm
I have noticed that the program crashes on all the Nov versions here when It's running in the background and I start browsing with Edge. Not right away but after about three or four clicks to different websites, QRZ, etc. Thetis version Setup_7Oct19_c5.msi does not crash.
EA1DAV
Re: 2.6.8
Postby EA1DAV » Mon Nov 04, 2019 9:41 pm
My Anan 100D don't start the radio. Before work like a champ. In setup the radio and firmware versions are rigth. :!:
w2ner
Re: 2.6.8
Postby w2ner » Mon Nov 04, 2019 11:17 pm
To whom it may apply
Richie has been working very hard to help get some of the bugs out and to improve the interface. You need to be aware that with the verations from one system to the next (not to even mention the firmware versions) there's going to be some outcomes that may not fit into the normal expectations. Richies is volunteering to do this on his own time, he does not get paid, So please as a group just post information as to errors and not bombard him with unnecessary comments or questions. I respect his hard work and every step forward due to his dedication is a step we did not have in the past.
Richie, I can't put into words the appreciation I have for everything you have been doing. I don't take all this hard work for granted and again, thank you!!
Re: 2.6.8
Postby ramdor » Tue Nov 05, 2019 12:43 am
w-u-2-o wrote:Hi Richie,
odd, if you have the old db, I would appreciate a copy
Re: 2.6.8
Postby ramdor » Tue Nov 05, 2019 12:45 am
W2SDR wrote:I have noticed that the program crashes on all the Nov versions here when It's running in the background and I start browsing with Edge. Not right away but after about three or four clicks to different websites, QRZ, etc. Thetis version Setup_7Oct19_c5.msi does not crash.
please provide screen capture of crash/exception message, machines specs, and ideally a video of it happening
Re: 2.6.8
Postby ramdor » Tue Nov 05, 2019 12:46 am
EA1DAV wrote:My Anan 100D don't start the radio. Before work like a champ. In setup the radio and firmware versions are rigth. :!:
make a backup of your DB+wisdom files, and try with a fresh database. What version did it work with before?
Re: 2.6.8
Postby ramdor » Tue Nov 05, 2019 12:53 am
cheers Nicolas. With so many variants, different firmware, database issue, etc all becomes a bit tricky. There could be an oddity in the db version converter if Scott was previously working however.
Re: 2.6.8
Postby w-u-2-o » Tue Nov 05, 2019 2:19 am
Hi everyone,
First, a big, big, big thanks to Richie for all of his tremendous effort. I'm trying to convince my company that a meeting is needed in the UK just so I can get over there to buy him a few pints, at least! :D
Second, per Richie's request, we are going to lock this thread. Further discussion should continue in the 2.6.9 thread which Richie has already started.
Many thanks to everyone for their outstanding support to Richie and the development process. Please continue to make very careful assessments of whether the bugs your are experiencing are firmware related or Thetis related, and always check against a reset database first before blaming any new code--I myself fell for that trap today. The database is a complex, living, breathing thing, and there is a lot of code that Richie hasn't touched yet that can make a database go from perfect to non-functional in an instant. By being sensitive to these things we can make sure that Richie isn't chasing ghosts instead of writing awesome code!
Thanks, and see you in the 2.6.9 thread!
