2.6.8
2.6.8
Some nice additions with the new V2.6.8 Thanks to all the developers with moving Thetis forward!
Re: 2.6.8
HI all
and thanks for the good job done. This version looks very nice. especially the user
interface looks great.
Unfortunately the transverter facility is still not functionnal as in the previous version.
- the PA disable seems to work : there is no (as it should be) output on the antenna but still a rise in the current draw. (5 to 6 amperes,
max no matter what drive level is set in Thetis)
- there is NO output on the xvrtr rear ouput.
So I had to go back to HPSDR mrX to continue my work on my homebrew transverter.
73s Phil FM5GB
73s Phil FM5GB
Re: 2.6.8
Great job guy's...the meter is great , now I can see it across the room.
For some reason the software lost the feature of "Show CT H Line" .
It's under Setup/General/Options , Miscellaneous .
Any input ?
oxt
Any input ?
oxt
Re: 2.6.8
Fantastic job to all involved. I know this takes a lot of time and dedication to evolve this software to the point its at.
- Kudos.png (153.87 KiB) Viewed 26293 times
Re: 2.6.8
Thanks to the team for delivering 2.6.8, it’s everything we’ve been waiting for. Only bug I’m finding is a problem when RX2 is active in conjunction with VFO SYNC. Can’t move frequency beyond an Amateur Band Edge. Hope this is a simple fix.
Jeff NJ2US
Jeff NJ2US
Re: 2.6.8
Thetis version 2.6.8 can be downloaded from
https://github.com/w5wc/Thetis/releases/tag/v2.6.8
Jeff NJ2US
Jeff NJ2US
Re: 2.6.8
jeffreydoran wrote:Only bug I’m finding is a problem when RX2 is active in conjunction with VFO SYNC. Can’t move frequency beyond an Amateur Band Edge.
I am also experiencing some weirdness when trying to recall a Memory when VFO sync is enabled. Relays in the 7000DLE just start chattering away. But it's not all memory freqs, just ones which are outside the ham bands, and then only certain ones.
Re: 2.6.8
I noticed when doing a clean install, the program is asking for the latest version of .net frameworks... https://dotnet.microsoft.com/download/dotnet-framework, after that it worked like a charm... Also found a glitch when you go into Setup / Appearance and check the LED box, VFO A and B goes haywire...
Re: 2.6.8
NC3Z wrote:jeffreydoran wrote:Only bug I’m finding is a problem when RX2 is active in conjunction with VFO SYNC. Can’t move frequency beyond an Amateur Band Edge.
I have tracked down this problem, related to trying to update RX2 band via cat commands.
Re: 2.6.8
Thank you to all the developers for all the work done to put version 2.6.8 together. The improvements to the GUI are very much appreciated as is everything that was done under the hood. It has been very stable for me with my 200D using F/W v1.8 and I look forward to running through all the features and menus to check it all out.
Re: 2.6.8
ramdor wrote:I have tracked down this problem, related to trying to update RX2 band via cat commands.
That was quick!
Re: 2.6.8
The official release will be coming soon. It will include voluminous release notes.
Re: 2.6.8
NC3Z wrote:ramdor wrote:I have tracked down this problem, related to trying to update RX2 band via cat commands.
That was quick!
Hah yes Gary, I had planned on not looking at the code again until end of month, but that specific bug would have annoyed me. It is related to forcing rx2 to update band settings, designed to fix an issue with the related CAT command.
Bands outside ham bands are identified in code, for example B49M just under the 60M band, and trying to set B49M to the rx2 drop down would not do anything, and a subsequent call to update with the selected entry would just re-select a ham band, and make it look like you could not leave.
Anyway, all fixed, but looking at a couple of other issues that have cropped up and will get it back to Doug tomorrow.
Re: 2.6.8
i mainly uses my anan 200d in digital modes, uses dxlab (commander and omnirig to control rx2 (wsjt-x 2.1.0)
it is very unstable jumping of band if i touch the gui
but when dialed in it works ok rx2 is unstable with omni rig
LA5SJA Geir
LA5SJA Geir
Re: 2.6.8
ramdor wrote:NC3Z wrote:ramdor wrote:I have tracked down this problem, related to trying to update RX2 band via cat commands.
That was quick!
WOW RIchie, that was quick! You're the man!!
Re: 2.6.8
Those having issues with tune on RX2 please try....
https://www.dropbox.com/s/icbq8g8eq7mc4 ... x.zip?dl=0
A couple of fixes I managed to sneak in. I will send off to Doug tomorrow.
- improvement: sync only updates RX2 mode/filter if different to RX1
- change: setting of RX2 band via CAT handled differently to fix issue with rx2 band drop down not having all possible bands
- fix: RX2mode panel now shown in correct place when coming out of collapsed view
Re: 2.6.8
Richie, your code fix appears to have corrected all issues regarding RX2 out of band movement and memory selection. These are exciting times for OpenHPSDR thanks to you, Doug, this forum, and the Apache team. Looking forward to more magic!
7000DLE Thetis 2.6.8 (Richie fix)
Jeff NJ2US
Jeff NJ2US
Re: 2.6.8
For those wishing to test : https://www.dropbox.com/s/uku1batvjvckz ... 9.zip?dl=0
- fix: LED font issue is resolved
- added: shutdown splash screen
- fix: white popup windows that were showing during shutdown, now not shown
Re: 2.6.8
Glad to see some more smart folks moving Thetis forward. I think Apache is finally enjoying some recognition on how good the TX and RX really is.
Re: 2.6.8
ramdor wrote:For those wishing to test : https://www.dropbox.com/s/uku1batvjvckz ... 9.zip?dl=0
Richie, you seem to always be amazing us. Love the great work!
Re: 2.6.8
The 9/12 fixes are working great Richie. The Shutdown Splash is a nice addition, and welcome. The excitement in the OpenHPSDR community is palpable, Thanks for the continuing magic, "Its like getting a new radio".
Jeff NJ2US
Jeff NJ2US
Re: 2.6.8
For when you have time I have noticed another anomaly. Here is a video of what is happening https://www.youtube.com/watch?v=Kc45hMwbixg
If I have VFO Sync On the problem is not there. As I tune VFO A and tune from a ham band out of it the VFO A Band buttons switch as expected and all is smooth.
However if I take VFO Sync off and do the same with VFO A then the band buttons flash and may or may not switch. Also the VFO tuning becomes very jumpy.
Re: 2.6.8
NC3Z wrote:For when you have time I have noticed another anomaly. Here is a video of what is happening https://www.youtube.com/watch?v=Kc45hMwbixg
very odd, and I take it you are using the exe I posted above with the fixed RX2 tune issue?
Try something at let me know if any change. Select a different Region in Setup->General->Region drop down, hit OK, then set it back to what it should be, then test vfo behaviour again.
Re: 2.6.8
Thank you, Doug and Richie! Nice work!
Re: 2.6.8
ramdor wrote:Select a different Region in Setup->General->Region drop down, hit OK, then set it back to what it should be, then test vfo behaviour again.Richie.
Yes I am using the latest dropbox version you posted today.
So I use Extended region for a legal and legitimate reason. Switching to US Region and the problem goes away, switch back to US and it's gone.
Re: 2.6.8
NC3Z wrote:ramdor wrote:Select a different Region in Setup->General->Region drop down, hit OK, then set it back to what it should be, then test vfo behaviour again.Richie.
ok thanks Gary, will look at it later/tomorrow. Same flickering behaviour here with extended.
Re: 2.6.8
200D running 1.8 Orion firmware om Windows 7. TX bug to rteport.
2.6.8 works great on RX. However on clicking TUN or MOX or PTT it crashes out. Tried resetting database, but still the same problem.
Have been using 2.6.7 for a while. This is reasonably stable but I still have occasional VAC problems (runaway over or under sampling) maybe once or twice in a day.
I have reverted to 2.6.7. Will await further developments with 2.6.8.
73 Dave G3ZQH
73 Dave G3ZQH
Re: 2.6.8
Another minor issue I noticed when in Collapsed view. As you toggle the radio buttons between RX1 and RX2 the S meter size changes.
Re: 2.6.8
What would be great to have is, being able to have two separate windows, one for VFO 1 and one for VFO 2. This way us guys who run multiple monitors can benefit by having full size and separate waterfalls and pan adapter. One VFO on each monitor.
Oh and being able to set up multiple notch filters in a single pan adapter.
ok, I'll stop now before I get carried away.
