Thetis 2.6.6 released
Postby w-u-2-o » Sun Apr 21, 2019 7:40 pm
This is a small maintenance release to fix the following bugs:
- Displaying EU region numbers
- Out of band errors on startup
- Transmit filter not displaying in split mode
DL8LAQ
Re: Thetis 2.6.6 released
Postby DL8LAQ » Mon Apr 22, 2019 9:34 am
w-u-2-o wrote:https://github.com/TAPR/OpenHPSDR-Thetis/releases
I tried split in CW and SSB. In CW the VFO B carrier freq will be displayed in yellow and the RX filter if MultiRX is enabled. That is fine.
But in SSB I can't see VFO B on the panafall without enabling MultiRX!
73, DL8LAQ - ANAN-7000DLE
Postby w-u-2-o » Mon Apr 22, 2019 11:16 am
Try enabling TX FL.
Postby Tony EI7BMB » Tue Apr 23, 2019 3:19 pm
Edit : Apologies this was already covered in Scotts installation notes. RTFM for me :-)
ea3aqr
Postby ea3aqr » Tue Apr 23, 2019 5:33 pm
Check in the left side under "profiles" (setup/transmit)
FM5GB
Postby FM5GB » Wed Apr 24, 2019 2:41 am
Thank you Doug !
You did a great job
I installed V2.6.6.0 and switched back the Win7 region setting to France.
No trouble now : Thetis launches flawlessly.
When I had region UK selected I lost my HamRadioDeluxe Logbook (old free version 5.0)
and it did'nt come back after resetting France as region. I did not investigate why but purchased
the latest HRD version and now I am a happy camper.
Best 73s Phil FM5GB
DL8LAQ
Postby DL8LAQ » Thu Apr 25, 2019 10:58 am
w-u-2-o wrote:Try enabling TX FL.
That did not do the job. I started again with a reset db. Now I have the two yellow vertical lines show the ssb tx filter.
