Added receive HPF filter control to main console
Posted: Wed Jul 18, 2018 2:50 pm
I have added the button controls on the Thetis main console to control - bypass / engage the receive HPF filtering. I have an 8000dle so this is for the two filter units separately. Also, when you engage the “WB” wideband window mode the HPF filter 1 bank triggers bypassed and indicates on the button so you don’t have to manually bypass for wideband reception window. I use the “collapsed” display a lot so hope to show these buttons on that screen as well but have not worked that out yet. I wanted to be able to put this out for others with the 8000 / 7000 models if they wanted this option but not sure of the best way for this? This is installed in the latest 2.60 version, I changed to 2.61. Maybe I could email zip folder of files for someone to check out.
Thanks and 73’s
Thanks and 73’s
