2.6.9
VA2EY
Re: 2.6.9
Postby VA2EY » Tue Jan 07, 2020 12:21 am
I have a little problem with Pure Signal since version 2.6.9_C1. I use about 15 seconds and the Pure Signal no longer works. The PS-A button is still working, but the two green Correcting and Feedback boxes turn black. Tried several times always the same problem.
Version 2.6.9_B6 and previous version work well. Installation with new database.
Another less important remark, at the first installation the microphone did not work, it has to function correctly after restarting software
Anan100D Angelia_Protocol_2_v11.7_7-15-18
Michel
Re: 2.6.9
Postby ramdor » Tue Jan 07, 2020 9:32 am
VA2EY wrote:I have a little problem with Pure Signal since version 2.6.9_C1. I use about 15 seconds and the Pure Signal no longer works. The PS-A button is still working, but the two green Correcting and Feedback boxes turn black. Tried several times always the same problem.
Michel
only changes to b6 to make c1 :
fix for qsk antenna rx/tx issue - would not impact PS
andomeda changes - would not impact PS
I have a feeling that reports of PS-A working in b6 and not in c1 are somewhat bogus imo, but stranger things have happened i'm sure.
Re: 2.6.9
Postby w-u-2-o » Tue Jan 07, 2020 7:59 pm
Serial port CW keying connections are not working properly on 2.6.9 b6 (and using an 8000DLE with pre8).
1. The serial port CW PTT line function does not operate under any combination of CW modes and controls. Thetis does not go into a TX mode (and not emit RF) when the serial port CW PTT line is asserted. Expected behavior is that, with QSK OFF and Semi Break-In ON or OFF, asserting this signal should put the radio into TX mode but not emit RF energy.
2. With Semi Break-In disabled (unchecked), the serial port CW Key Line input also does not work. Expected behavior is that asserting this signal should put the radio into TX mode and emit RF energy, regardless of the state of the CW PTT signal.
3. With Semi Break-In enabled, QSK on or off, the serial port CW Key Line input does work. The radio goes to TX mode and emits RF energy. So that part is OK as long as Semi Break-In is enabled.
I can confirm that both RTS and DTR control modes work OK. I can switch back and forth between them for key line and it works as expected.
This is a Thetis problem at the very least--even if the firmware had an issue the software should at least change to a TX state.
For reference and clarification:
When DTR is selected one shorts DE9 pin 4 (DTR output) to DE9 pin 6 (DSR input) to assert the function.
When DSR is selected one shorts DE9 pin 7 (RTS output) to DE9 pin 8 (CTS input) to assert the function.
A sample set of settings is shown below. For my testing COM1 is a real, hardware serial port (a virtual port can be used if desired).
It is worth noting that if QSK and Semi Break-In are enabled, remote, full QSK performance, including sidetone if DUP is ON, is possible on Orion and Orion MKII hardware. This can be a straight key using a serial port on the Secondary connection, or a paddle using a serial port on the Primary connection. The latter works perfectly, with dots when asserting DTR and dashes when asserting RTS.
KB1YFD
Re: 2.6.9
Postby KB1YFD » Wed Jan 08, 2020 12:51 am
Nice work! I'm running an Anan 7000DLE, Thetis 2.6.9 b6, ver 2 pre8.
Found a small bug. Drive slider does not work in tune mode.
Best, John
Re: 2.6.9
Postby w-u-2-o » Wed Jan 08, 2020 2:13 am
John,
I can't remember if this is the case for PowerSDR, but I believe you always had to have "Use Drive Power" checked in Setup > Transmit > Tune for the drive slider to control tune power level.
W1AEX
Re: 2.6.9
Postby W1AEX » Wed Jan 08, 2020 3:28 am
It used to be that you could set the drive power for Tune on the Transmit menu tab and when you went into Tune mode it would use that value. However, you could then adjust the drive slider and it would over-ride the pre-set value for that session of Tune.
I think that was really the best way for the Tune control to work.
artcomm
Re: 2.6.9
Postby artcomm » Wed Jan 08, 2020 3:57 am
Hello Gents, hoping someone here can direct me to the pro2 ver2.0-pre8 Firmware maybe a URL? or email to me n4qnt@twc.com
Thank you,
Art
iw3fvz
Re: 2.6.9
Postby iw3fvz » Wed Jan 08, 2020 9:11 am
w-u-2-o wrote:Serial port CW keying connections are not working properly on 2.6.9 b6 (and using an 8000DLE with pre8).
Problem like this... https://apache-labs.com/community/viewtopic.php?f=27&t=3142 ????
NC3Z
Re: 2.6.9
Postby NC3Z » Wed Jan 08, 2020 12:12 pm
artcomm wrote:Hello Gents, hoping someone here can direct me to the pro2 ver2.0-pre8 Firmware maybe a URL? or email to me
Or you could just go to the Firmware part of this forum and get it yourself ;)
viewtopic.php?f=32&t=3192
artcomm
Re: 2.6.9
Postby artcomm » Thu Jan 09, 2020 3:27 am
Thank you.. Got it
NC3Z
Re: 2.6.9
Postby NC3Z » Thu Jan 09, 2020 11:53 am
There is a wealth of info on this forum, but you sort of have to dig around. But Scott did make the important ones sticky at the top.
dl6eat
Re: 2.6.9
Postby dl6eat » Sat Jan 11, 2020 5:10 pm
On Saturday, December 28th I came up with a question regarding the "non moving Worldmap". It appeared to me that either Sun Tracking and Gray Line Track are not moving at all, After some in-depth tests - and an info of a friend who tested that also - I have to correct this at least half way:
Once "Disable PicDisplay" is disabled and the Spot menu is enabled accordingly it's important to leave the "Spot" window open (do NOT close it!)! If it's still open and running Gray Line and Sun Tracking are moving every 2 minutes.
If it's not too much work it would be simply nice to have this option available on startup one day - as of now it disappears every time when closing Thetis.
May be it's simple and a check box can be implemented which allows auto-start?
Would be great as most HF operators are keen to see at least Gray Lines......right now we use Simon's WorldMap in an additional application.
Thanks for reading - 73,
Andy
Just SDR - no knobs, no sliders but Pure Signal and Open Source only :lol:
ANAN 7000, ANAN 10, two Intel NUCs - some amps and some antennas - ready to go...
Re: 2.6.9
Postby ramdor » Sun Jan 12, 2020 6:00 am
UPDATE
link updated to c2_1
HI all,
Quick update, please try : https://www.dropbox.com/s/emiuraz9we7pv ... 1.zip?dl=0
  • QSO timer settings added to Options2 tab until a sort out/tidy of the setup happens.
  • Left click on the timer on the status bar to enable/disable, or right click it to reset.
  • If 'only during mox' is enabled the left click start/stop has no effect and is purely driven by mox.
  • Reset on mox does just that, every time mox/tx starts the timer is reset.
  • The sound playing is very simple and uses the default sound device in windows. There may be future work to integrate this into a specific audio device and/or mix with other streams.
  • The timer flashes in status bar when expired, and also play the sound once if set in options
  • Tooltips have more info
Annotation 2020-01-12 164534.png (23.07 KiB) Viewed 518 times
(1/4/20) c2_1
-add: auto timer reset on expiration + flash continuation, some other bits tidied
(1/4/20) c2
-fix: TX profile was incorrectly being selected during saving/updating when modes use different profiles (thanks Ultimax for spotting this)
-add: spectral area gets surrounded in red if high swr
-change: statusbar clock updated once per second instead of 10 times per second
-add: QSO timer, left click start/stop, right click reset. When in Mox activation only mode left click is ignored. Flashing timer if elapsed, with optional sound played through default windows audio device
NC3Z
Re: 2.6.9
Postby NC3Z » Sun Jan 12, 2020 1:47 pm
Nice Timer option. Once it is all working I can remove HamTimer that I use for this exact feature.
Any way you can add an option to reset once it hits the Expiration and count again?
Re: 2.6.9
Postby ramdor » Sun Jan 12, 2020 2:06 pm
NC3Z wrote:Any way you can add an option to reset once it hits the Expiration and count again?
yep, will do a repeat option, forgot about that :D
NC3Z
Re: 2.6.9
Postby NC3Z » Sun Jan 12, 2020 3:51 pm
Perfect! Will not need HamTimer anymore.
Re: 2.6.9
Postby ramdor » Sun Jan 12, 2020 4:48 pm
Update post above has new links to c2_1
73 Richie.
W1AEX
Re: 2.6.9
Postby W1AEX » Sun Jan 12, 2020 5:14 pm
Thanks for C2_1 Richie. Love the QSO timer with auto-reset and how quick and easy it is to use. Everything is working very well with 2.6.9 (c2_1) here.
Re: 2.6.9
Postby ramdor » Sun Jan 12, 2020 5:23 pm
W1AEX wrote:Thanks for C2_1 Richie. Love the QSO timer with auto-reset and how quick and easy it is to use. Everything is working very well with 2.6.9 (c2_1) here.
nice one Rob. There may be some other ideas for it from others, but it seems to work ok. The audio playback is quite simple for now.
w4cm
Re: 2.6.9
Postby w4cm » Sun Jan 12, 2020 6:58 pm
Just some thoughts on the new option.
If the new timer was expanded into a full id'er option the other functions could be :
Keys radio and plays audio recorded file or cw id file.
Detects radio keyed and wait for un-key to play id
Option to sync with clock and id on the tens. This would sync all users on id time.
Cecil
W4CM
NC3Z
Re: 2.6.9
Postby NC3Z » Fri Jan 17, 2020 7:26 pm
Not sure where it broke but I am on c2_1 and Pre8 FW. I can no longer get Quick Record to play back over the air.
When in RX the audio will play when I hit Play, but if I am in TX it will not send the audio. I do see energy on the VOX meter, but not on any other meter.
I also observe the TX EQ turning off (as it should) when I tell it to play the audio during TX.
Anyone else try Quick Rec and playback to see if it works?
