I'm not sure if it's by design, but I'm seeing a PA Profile banner inserted into Thetis' display when alternating between screen expand and collapse. At least in my case, it overwrites onto the custom containers. A right-click on the banner opens up the PA settings window, but there's no option to remove it. Screen capture attached.
Thetis v2.10.3.3
PA Profile Banner Showing in Thetis v2.10.3.3
Re: PA Profile Banner Showing in Thetis v2.10.3.3
its zorder is probably above the container user control when docked, will fix for 2.10.3.4
you can report bugs over on github which makes things easier to track
https://github.com/ramdor/Thetis/issues/new/choose
ramdor wrote:its zorder is probably above the container user control when docked, will fix for 2.10.3.4
Thanks, Richie.
I have been working a bit with the collapsed view code, the pa profile tag had to be re-located for that view. I placed it at the lower screen view in collapsed. I have not uploaded anything yet to my repo. I worked on a few other items in the collapsed view that may be of interest to Richie but he will need to check it out and correct where necessary, I know and definitely trust his expertise. I mainly use the collapsed view as I like less clutter with slightly used controls. Sorry for the ramble and much thanks to Richie!
73’s
73’s
The label gets relocated when collapsed/expanded are used, however I had left some test code in there to bring label to top which was not needed anymore.
