band edges
band edges
Postby oe3ide » Tue Jul 13, 2021 7:34 pm
just noticed on the 40m band, that the band edges (red vertical lines) are not corresponding with the values in the database.xml.
Selected region in setup is "Europe".
Same on 80m. IARU 1 ends at 3.8 Mhz. Red band-edge line is at 4 Mhz.
Any ideas?
See screenshots...
Re: band edges
Postby ramdor » Tue Jul 13, 2021 8:16 pm
Nope, they are hard coded into the display class. I remember having to update them in there at some point a couple of years ago now. All needs a re-work sorry to say :/
Re: band edges
Postby oe3ide » Tue Jul 13, 2021 8:23 pm
Ok, thanks Richie for the info. I thought I am doing something wrong..
DO2ZA Erwin
Re: band edges
Postby DO2ZA Erwin » Wed Jul 14, 2021 11:14 am
Hi Ernst and Ritchie,
here at my Side all is ok, 80 m 3,5 -- 3,8 Mhz, 40 m also 7,000 -- 7,200
Using 21c Prot. 2 EDIT: Region is set to Germany
Greetings
Erwin
Re: band edges
Postby oe3ide » Wed Jul 14, 2021 12:28 pm
Ok, just set the region to "Region 1" ... all perfect now.
Thank you Erwin, for the tip!
