8000dle and sdr console ver 3.0.022
N2XD
Postby N2XD » Tue Apr 21, 2020 8:35 pm
I just downloaded ver 3.0.22 of sdr console. My first attempt to use SDR Console. Started SDR console and it operates for around 30 seconds and stops. I know I'm missing something on my end, I have the 8000DLE selected I stop the SDR console and restart and the same thing happens. Any help would be appreciated. Thanks.
John N2XD
PD3LK
Re: 8000dle and sdr console ver 3.0.022
Postby PD3LK » Tue Apr 21, 2020 11:24 pm
Hi John, do you have updated the 8k with Protocol 2? SDRC doesn't work with Prot.1.
If you have P2 than it's proberbly a bad network connection or your router is to slow. P2 needs a 1Gb connection.
Postby Tony EI7BMB » Wed Apr 22, 2020 10:12 am
I had this problem and it turned out to be the firewall . https://www.sdr-radio.com/ANAN-Apache-Labs
N2XD
Postby N2XD » Wed Apr 22, 2020 11:56 am
Thanks for the suggestions. I am running the Ver 2 of the firmware as I am running the latest ver of Thetis and running on the same same router connection. I did check the firewall and all is fine there. I will have to keep looking.
John
Postby W1AEX » Wed Apr 22, 2020 2:19 pm
Hi John,
I'm not sure how closely you looked at the firewall but Tony is correct that this is an acknowledged issue with the Windows firewall making duplicate rules that will block the "ack" confirmation handshake with SDR Console shortly after the program is started. When I encountered this problem with SDR Console I found a rule that was blocking TCP and UDP communication and set the rule to "Allow" and thought that was the end of it. Well... that didn't fix it because as it turns out, the firewall had made numerous duplicate rules blocking the connection for SDR Console. I cleaned all the "Not Allow" rules out (there were more than a dozen of them) and before starting SDR Console again I created an allow rule for TCP/UDP to allow communication for SDR Console. That seems to have ended the problem for me. At any rate, you might want to take a second look at all the rules that are up and down the list in the firewall, you may find that the firewall has been busy creating them without displaying a prompt to ask you.
N2XD
Postby N2XD » Wed Apr 22, 2020 3:10 pm
Hi Rob,
I will check this again. This might be beyond my pay grade. However it should be an adventure. Thanks.
John N2XD
Return to “SDR Console”
