PowerSDR mrx Fails to Load
Posted: Sun Jun 24, 2018 8:09 am
I have been using PowerSDR 3.4.9 for a couple of months without problems. It now fails top load, stopping half way through with an error message - 'Windows is checking for a solution to this problem' followed a second later by 'A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is found'. It hasn't.
T^he computer runs windows 7, I have a working virus checker and scans report no problems. 'Restoring' the system to an earlier date when working does not resolve the problem. Down loading a new version of 3.4.9 or 3.4.8 result in the same failure.
Has anyone any suggestions?
Malcolm MM0DKQ
Malcolm MM0DKQ
