PowerSDR mrx Fails to Load
MM0DKQ
Postby MM0DKQ » Sun Jun 24, 2018 8:09 am
I have been using PowerSDR 3.4.9 for a couple of months without problems. It now fails top load, stopping half way through with an error message - 'Windows is checking for a solution to this problem' followed a second later by 'A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is found'. It hasn't.
T^he computer runs windows 7, I have a working virus checker and scans report no problems. 'Restoring' the system to an earlier date when working does not resolve the problem. Down loading a new version of 3.4.9 or 3.4.8 result in the same failure.
Has anyone any suggestions?
Malcolm MM0DKQ
MM0DKQ
Re: PowerSDR mrx Fails to Load
Postby MM0DKQ » Sun Jun 24, 2018 11:04 am
My apologies! I have now read the post from GW0QW on May 24th and tghe suggest6ion from NC3Z that the current data base was the problem. As suggested I restored a previous database from archive and all is now working.
Many thanks
Postby NC3Z » Sun Jun 24, 2018 11:22 am
Saves me from posting!
GW0DQW
Postby GW0DQW » Wed Jun 27, 2018 8:41 pm
Well done Malcolm , first time I have any issue with the database, glad your is ok now.
I do back my database regularly.
Chris
GW0DQW
