Anan 7000DLE microphone configuracion PowerSDR mRX
W4RAM
Postby W4RAM » Wed Apr 04, 2018 8:10 am
Good morning
I am looking for assistance with my Anan 7000DLE.
I already finished the initial setup for the power out and also for the microphone of my Anan 7000DLE; to setup the power I did it manually by band and use dummy load to set 100W.
To setup the microphone, I followed the instructions in the manual; I am using a computer microphone (3.5mm connector with 3 parts).
However when I put the radio ready to operate, for example in 20 meters band, USB, this only puts 5-8 watts out when I speak for the microphone being the radio configured for 100w in the band that I am working.
I moved around the Transmit and General Tabs (PowerSDR), checking microphone configuration according the manual, but I can not find what I have missing about mic configuration to make the radio work properly.
Thanks in advance for any assistance or advice.
Alberto M.
DL/W4RAM
NC3Z
Re: Anan 7000DLE microphone configuracion PowerSDR mRX
Postby NC3Z » Wed Apr 04, 2018 11:45 am
Do yourself a favor and get a decent mic for the Anan, they are fantastic sounding radios and really deserve a good mic to go along with it, not a $3 PC mic, IMHO.
Lots of other questions too;
Mic Bias set correctly, mic gain, Comp/CFC on?
That being said read through Rob's instructions and make sure you hit all the stages with the right levels.
http://www.w1aex.com/anan/anan.html
Postby w-u-2-o » Wed Apr 04, 2018 1:04 pm
Alberto,
See these two threads right here in this very forum, "stickied" to the top of this very sub-forum, you can't mess them:
https://apache-labs.com/community/viewtopic.php?f=6&t=2550
https://apache-labs.com/community/viewtopic.php?f=6&t=2508
W4RAM
Postby W4RAM » Thu Apr 05, 2018 11:44 am
Thank you Mr. Gary for your recommendation about microphone, you are totally right!!!. Actually, I have another better option then an cheap pc mic, is a HMM Heil but unfortunately, has installed the wrong tip (two parts instead of 3 parts). Yesterday, following the recommendations that I get in this forum, I was finally able to correctly configure the transmission in my Anan 7000DLE. Thank you again.
Al
DL/W4RAM
W4RAM
Postby W4RAM » Thu Apr 05, 2018 11:48 am
w-u-2-o wrote:Alberto,
Thank you Mr. Scott for this valuable information, your assistance is appreciated.
Al
DL/W4RAM
Return to “PowerSDR mRX”
