PowerSDR mRX PS 3.4.4 Released
Postby w-u-2-o » Mon Nov 20, 2017 1:58 am
PowerSDR mRX PS 3.4.4 has been released. This release primarily addresses some bugs in 3.4.3 that could cause crashes. See the very bottom of the release notes for more information.
https://github.com/TAPR/OpenHPSDR-PowerSDR
Re: PowerSDR mRX PS 3.4.4 Released
Postby Tony EI7BMB » Mon Nov 20, 2017 9:50 am
I like the feature, separate TX profiles per mode , thanks guys
WA2DVU
Postby WA2DVU » Mon Nov 20, 2017 1:01 pm
w-u-2-o wrote:PowerSDR mRX PS 3.4.4 has been released. This release primarily addresses some bugs in 3.4.3 that could cause crashes. See the very bottom of the release notes for more information.
I am waiting for my 7000 to arrive and a few weeks ago I loaded 3.4.2 to play with. Downloaded 3.4.3 and installed in same pc and it worked fine. Downloaded 3.4.4 and when unzipped all I had was a bunch of text. What am i missing to load the actual program? 73, Bill, WA2DVU
Postby Tony EI7BMB » Mon Nov 20, 2017 1:55 pm
S. Furukawa
Postby S. Furukawa » Mon Nov 20, 2017 2:39 pm
Hello OM
I tried CW keying from CAT Connections in version 3.4.3.
CW keying is strange. The lengths of the dots and dashes and the interval between them are not constant.
In version 3.4.2 and earlier versions, this symptom does not occur.
How is version 3.4.4.
I'd like to try version 3.4.4 myself now. I can not try now. Because, my ANAN-200D is not in my house now.
Has anyone tried CW keying from a CAT connection with version 3.4.4?
Please give me advice.
My TRX: ANAN-200D
Virtual COM: VSP Manager version 1.0.3.01
Loging Software: Win-Test, N1MM+ and others.
OS: Windows10pro Japanese
Thank you and regards,
73 Shige JG3KIV
ULTIMAX
Postby ULTIMAX » Mon Nov 20, 2017 4:09 pm
I uploaded the new software and I notice that no TX signal shows in the screen while in Panafall like before only if you engage the DUP button then you can see your TX signal , that didn't happen before because I never have that button lit up.
Any ideas ? maybe a bug
Also can something be done about the delay in the panadapter while in Collapse ? when you TX and you let go of the PTT there's a delay in the signal spectrum and is annoying.
Thank you
Al
N3YV
Beefus
Postby Beefus » Wed Nov 22, 2017 4:40 am
Hey Guys,
Appreciate the continuing updates and new features. Do have a minor glitch that is
keeping me at V3.4.2 with my Anan 100B. I like to quickly jump around with the five band stacking
registers that each band has. There is a noticeable delay now that started with 3.4.3, especially
when changing bands or if AM to SSB mode switch occurs.
The Firmware is V 1.5. Computer is NUC SKull I7 with 32 GB of RAM.
Jack, WB8BFS
Postby w-u-2-o » Wed Nov 22, 2017 1:15 pm
I'll add my own bug report (this is on an 8000 under Win10Pro):
With RX2 turned on A<>B and A<B do not work correctly, particularly if the two receivers are on two different bands.
Return to “PowerSDR mRX”
