PowerSDR mRX PS v3.4.2 A wish list
Posted: Sat Jul 08, 2017 4:14 pm
Very many thanks for v3.4.2 Using it with an ANAN10 and transverters on the low level output.
It must seem the more you give us, the more we want......Anyway on the basis of, if you dont ask etc. Could you please consider the following for future releases.
1. When the database is restored following a new release, to include MNF data in the restored data.
2. Recently noted that the RIT count will change even if RIT is off, Or has it always been like that?
3. Others have asked for Mode to be linked with frequency for the Band Stack. I would find that very useful for VHF use.
4. I find the Band Stack in the VHF section is still on 3 sections. Not a big problem, but for consistency....
5. I do a lot of VHF contesting and in QSB conditions will have to switch to CW quickly. Maybe it is only when using XVTRs, but I find the SSB setting
for Drive, to be much too high for CW. This results in overdrive in the heat of a contest, until I realise what is going on. Hence my request for a Drive control linked to the CW mode selection that can be preset for the correct CW drive.
Love the new CTUN thank you.
Geoff G3NPI
Geoff G3NPI
