PowerSDR mRX PS 3.3.16 released
Posted: Mon May 15, 2017 12:06 am
From Doug, W5WC:
All,
PowerSDR/OpenHPSDR mRX PS v3.3.16, May 14, 2017 has been released.
This release can be downloaded from the TAPR Github website.
https://github.com/TAPR/OpenHPSDR-PowerSDR/releases
This release contains the following changes/fixes:
- Corrects sporadic HIGH SWR message found in v3.3.15. Your radio should
have the latest firmware flashed.
- Chris, W2PA added support for the Behringer CMD Micro and CMD PL-1 MIDI
controllers in the Midi2Cat interface. More information can be found in the
BehringerMods_Midi2Cat_v2.pdf located in the PowerSDR working directory.
- Chris, W2PA added a RIT/XIT sync feature to the console that increments
RIT and XIT the same amount when adjusting either of the values.
- Corrected an issue with the 'Limit Stitched Receivers' feature not
updating when using the 8000DLE.
- Added 200W Meter Trim range for the 8000DLE.
This release dos not implement the CFC audio tools or SSB w/carrier
features.
You will need to reset your database for this release.
Thanks & 73
Doug, W5WC
All,
features.
Thanks & 73
Doug, W5WC
