anon 7000 DLE MKII PowerSdr MRX PS
Falcon
Postby Falcon » Sat Apr 24, 2021 3:06 pm
Greetings to all finally got logged in so here goes:
I have the 7000 DLE MKII i have it working fine with Thetis v.2.8.11 My PC is directly connected to the Anon.
The issue is i would like to experiment with Power SDR mRX PS but the program will not see the radio even when i switch the "bootloader" switch.
I have even tried the HPSDR Programmer to discover the radio it fails every time.
I have also tried SDR console 3.0.24 it does connect but cannot get it to transmit yes the radio keys up but get no audio through.
I use a boom mic into a Behringer UM2 and from there into line in on the Anon and as stated works fantastic with Thetis.
still a newbie and lots to learn.
thank you for any help.
N8LLC-John.
Re: anon 7000 DLE MKII PowerSdr MRX PS
Postby w-u-2-o » Sat Apr 24, 2021 5:03 pm
Do you have Protocol 1 or Protocol 2 firmware loaded into your 7000? Thetis will work with either. PowerSDR will only work with Protocol 1 firmware.
Falcon
Postby Falcon » Sun Apr 25, 2021 5:57 pm
Thank you for the response as i understand looking in settings under F/W set i have RX1 Sample rate and RX2 Sample rate
Under each drop arrow i have 48000 to 1536000 soooo protocol 2?
Not 100% sure i am understanding correctly? lol.
Again thank you still trying to wrap the old grey matter around this and a looong way to go.
John.
N8LLC
Postby w-u-2-o » Sun Apr 25, 2021 6:41 pm
That's correct. You have P2 firmware. So PowerSDR will not work with it.
If Thetis is working well then there is absolutely no reason to bother experimenting with PowerSDR. Thetis is by far the more advanced client.
Falcon
Postby Falcon » Sun Apr 25, 2021 8:34 pm
Thank you again so i will delete the PowerSdr and on to more learning!!
Beware more questions to follow...............
be safe.
John.
N8LLC
Return to “PowerSDR mRX”
