How to post images?
If you forgot your password, please use the password reset feature.
For profile changes or private issues, please contact a moderator by email or PM (use "The team" link at the bottom of the page)
Segrest
Re: How to post images?
Postby Segrest » Fri Oct 11, 2019 9:34 pm
Or if your image file is on your local computer, you can simply scroll the reply editor window down a bit, click the Attachments tab and select the Add Files button. This causes a popup window to appear you select the file you want from you computer and upload it. You can then decide if you want to insert inline with your comments or at the end of your post (the default choice).
Note that there is a limit on how big a file you can post. Convert those JPG images to PNG images and most will fit.
Bob
KO2F
Return to “Forum Problems (like posting photos, etc.)”
